Check the wiring on that light. Also check the bulb with a couple of wires to the battery, or swap the bulb left to right to make sure the new bulb is okay.
? 6:06
www.youtube.com/watch?v=Mlb1V5vNgFM Jan 3, 2012 - Uploaded by 1A Auto Partshttp://www.1aauto.com/1A/HeadLights/Mercury/Sable/1ALHP00223 ... Find out why. Close. How to Install Replace Headlight and Bulb Mercury Sable 00-05 ... How To Install Replace Fog Lightand Bulb 00-03 Mercury Sable
If you checked for power inside the socket(power and ground) the bend the tabs in the socket to touch the bulb wires. They get hot and bend. pull them out a bit.
Chances are that is the bulb. Its a dual filament bulb. The brake portion of it is burnt out. try swapping it with the left side and see if it works then. If it works, get a new bulb.
go here. we can help you. Also, did you check the headlamp relay in the box under the hood? One relay is in box in front of battery, other is in narrow box along passenger side fender under the hood. swap left & rt headlamp relays to see if it changes.
i would take another look at the connector that goes to the bulb thats not working, if the contacts are burnt or have a green pwder like substance all over them you should replace the connector. hope this helps you and good luck!
