Question about Pioneer DEH-1700 CD Player
How do I set the clock on a Pioneer DEH 1700 - Pioneer DEH-1700 CD Player
Posted by orangebluesa on
Andrew Hayhoe
    New Friend:
  • 31 Answers
1. Press SOURCE and hold until the unit turns off.
2. Press AUDIO and hold until clock appears in the display.
3. Press the arrows to select the segment of the clock display you wish to set.
4. Press + or - to set the clock.
5. To cancel clock settings, press BAND. You can also cancel clock settings by holding down AUDIO until the unit turns off.
Posted on Nov 07, 2009
Installation wiring diagram for pioneer deh 1700
here is the link for the installation manual and user manual:
http://www.pioneerelectronics.com/PUSA/Support/CarAudioVideo/In-Dash/CD-Players/ci.DEH-1700.Support
see the installation manual page 1 far right side for wiring diagram is listed as other manual
Cheers!
Nov 17, 2009 | Pioneer DEH-1700 CD Player
How do i set the clock on my DEH-1700?
Toddakins05
To set the clock on the DEH-1700
1. Press SOURCE and hold unitl the unit turns off.
3. Press <- or -> to select the segment of the clock display you wish to set.
Note to cancel clock settings press BAND
Hope this helps
Issken
Nov 12, 2009 | Pioneer DEH-1700 CD Player
How do you adjust the time?
I have been told...
press the source button,
press the audio button till the clock display turns on,
press the arrows till you get the # you want to change,
press the + / - to get the # you want,
press the band button to turn off the clock setting.
This is what I have been told to do to fix the time on a Pioneer DEH 1700
Oct 31, 2009 | Pioneer DEH-1700 CD Player
How to set the clock
Press AUDIO and hold until clock appears in display
Press < or > to select segment of the clock display you wish to set.
Press + or - to set the clock time
Here is a link to the user manual in case you need to know how to do other things...
http://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/164711831DEH-1700%20OPERATION%20MANUAL.pdf
Sep 13, 2009 | Pioneer DEH-1700 CD Player
Preset memory not working on pioneer DEH 1700 radio
You must connect the constant hot wire (or there is a fuse blown somewhere).... it should either be orange or yellow at the rear of the pioneer radio ... it should be connected to a wire that recieves power even when the key is off ... that wire will depend on the car itself ... if you used a connector to plug into the factory wires (a good idea) that connecter should have a yellow wire that would supply a constant "hot" for your pioneer, if it doesn't there should be a fuse blown in the car fuse box.
Apr 06, 2009 | Pioneer DEH-1700 CD Player
Can't set the clock
Push the audio button for about 3seconds. Then the main screen should start to change/ blink like resetting your VHS player.
When you see the "clock" blink or soild, the increase volume button. if you need more instructions email me:
[email protected]
I want to get the pioneer DEH 2000hp or MP. that model is about $250.00 installed by a professional and you or I shouldn't have any problems..
Aug 04, 2008 | Pioneer DEH-1700 CD Player
I NEED TO KNOW HOW SET THE CLOCK ON A DEH-1500 PIONEER
Hi Elimo
Two pics as the manual had the paragraph separated. This is for DEH 2500 only. Let me know if you want the 1500 as well.
Nov 24, 2007 | Pioneer DEH-P2500 CD Player
Radio
Follow the instructions as per the diagram below. Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 25, 2007 | Pioneer DEH-1700 CD Player
Pioneer DEH-1700 CD Player Logo
435 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
Sumeet Sodhi
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
