Question about HP Pavillion ZV6000 Notebook
Forgot password on windows vista - HP Pavillion ZV6000 Notebook
Posted by raymond_wyat on
windowsdocto
  • 21 Answers
Vista?
Forgetting your Windows administrator login password. With no way to get into the system, you can’t even perform basic maintenance, let alone a thorough tune-up. Formatting is always an option, but we consider that a last resort. (Plus, guess who’s going to have to help reinstall all the programs lost after a wipe?) But all hope is not lost. There are a few ways to actually retrieve a lost Windows account password. Read on, and we’ll show you the light.
====1st Method====
The first thing which you check if you forget login password. When we install Windows, it automatically creates an account “Administrator” and sets its password to blank. So if you have forget your user account password then try this:
Start system and when you see Windows Welcome screen / Login screen, press ctrl+alt+del keys twice and it’ll show Classic Login box. Now type “Administrator” (without quotes) in Username and leave Password field blank. Now press Enter and you should be able to log in Windows.
Now you can reset your account password from “Control Panel -> User Accounts”.
Same thing can be done using Safe Mode. In Safe Mode Windows will show this in-built Administrator account in Login screen.
====2nd Method====
1. Reboot your machine.
2. Press F8 before the Windows boot screen appears.
o Do not press F5 as used on the NT/9x series of Windows.
3. You will be be prompted with a boot options menu.
4. Select the Start Windows in Safe Mode option.
5. Click through several self-explanatory screens until your reach the familiar 'Welcome' screen.
6. Note that this welcome screen is limited to 256 colors and 640x480 resolution because the primary graphics will have been set to the Windows Safe Mode software VGA adapter. You will not be able to change this mode even in Display options, while Windows is running in Safe Mode.
7. Find the icon for the Administrator user. If the default settings of your system haven't been changed, there should be no password for this account.
o The Safe Mode Welcome screen might display some of the other users on your system.
8. Login as the admin.
9. Press Yes at the prompt asking if you would like to continue using Safe Mode.
10. Continue on to the User Settings control panel. Here you can change any of the other passwords for user on the machine. Make any changes you want.
11. Reboot your computer. As long as you don't press any keys (i.e. F8) during the boot-up the computer will startup normally.
12. Login as the user for which you set the password.
====3rd Method====
Windows XP and further versions also provide another method to recover forgotten password by using “Reset Disk”. If you created a Password Reset Disk in past, you can use that disk to reset the password. To know more about it, please visit following links:
http://support.microsoft.com/kb/305478
====4th method====
Comparatively, using windows password Recovery Tool utility is a reliable and convenient method for solving the password problem. Normally, the program can easily reset the password to “Blank” with no -reformatting or installation. Do all the job for you automatically. Unfortunately, it is not safe to use some free recovery tool to recover windows password. So here is the recommend recovery tool:windows password Recovery Tool 3.0 .
Offical site: http://www.windowspasswordsrecovery.com
you could see the recommendation of articlesbase.
http://www.articlesbase.com/security-articles/how-to-reset-recoverfind-forgotten-windows-nt-2000-xp-2003vista-administrator-password-1282019.html#
====5th method====
If it doesn't work above ,I hope that you have some hacker friends.
Reference resource:
http://windowspassword.blog.com/
http://www.wikihow.com/Recover-Windows-Administrator-Password-if-You-Forgot-It
http://www.instructables.com/id/How-to-Reset-Recover-Forgotten-Windows-NT-2000-2001/
Posted on Nov 10, 2009
Anonymous
    Guru:
  • 77 Answers
It's a sickening,powerless feeling to be locked out of your own computer if you have lost windows vistal password.But don't worry,there are mamy ways to remove the lost password.
This method is easy for everyone to follow.
Download windows password key 8.0 and install it then burn the software to a CD/USB drive,then insert the newly created CD/USB drive to your locked pc and reboot your computer,then press "F2" to enter your BIOS setup,following the instruction to reset your lost windows password.
Posted on Jun 13, 2010
nelladlu
    New Friend:
  • 13 Answers
I think probably the easiest and safest way for you is remove your Windows OS Password with Windows Password Seeker. I found it at about.com PC support channel last week, and then I download it from http://www.passwordseeker.com and used it to remove the lost password within 5 minutes. Furthermore, this powerful tool no need to reinstall Windows.
Posted on Nov 08, 2011
melysa
    Scholar:
  • 33 Answers
Recomend you to use "Windows password rescuer professional",it is simple and safe,and can recover windows password in several minutes.You can free download here:http://www.daossoft.com/download.html,and try it free if you need. Follow the steps you can easily recover the password,It is only four steps:
Step 1: Download Windows Password Rescuer (three versions)
Download:http://www.daossoft.com/download.html
Step 2: Burn bootable CD/DVD or USB flash drive
Step 3: BIOS setting,setup your computer boot from CD/DVD or USB
Step 4: Reset Windows password by a few clicks.You also can create new windows user account by it.
GO to Windows Password Rescuer official site: 'http://www.daossoft.com/ 'for more info.
forgot password on windows vista - 10_8_2011_10_19_49_am.jpg10_8_2011_10_21_09_am.jpg
Posted on Oct 08, 2011
lemon yanyan
    Novelist:
    Scholar:
  • 175 Answers
You can reset Windows vista password with password reset disk if you have one created in advance. If not, you can use Windows Login Recovery software to recover your password. Free trial of Windows Login Recovery is available on its website. http://www.windowsloginrecovery.com
Posted on Aug 26, 2011
wuyibnuep
    Guru:
  • 171 Answers
  • CarryBlise Oct 12, 2011
    I know an easy way to recover Windows Passwords required no reinstalling Windows OS and no computer skills. You can download a windows password reset tool on the internet. It can reset Windows login Passwords. You could get back into Windows just within few minutes. I recommend this site http://www.reset-windows-password.com
Zhuliya Line
    Scholar:
  • 67 Answers
I have heard of a freeware software that can crack it. But I have never personally done it before so I will be of little help.
http://download.cnet.com/Windows-Password-Key/3000-2092_4-75031111.html
Posted on Mar 22, 2011
Nicolas_y
    Guru:
  • 243 Answers
If you lost windows password. I think the best solution is making a windows password recovery disk with the third part utility. The disk works perfectly to recover windows password to “Blank”.It is also useful for administrator password recovery, you can wrote it to an blank CD or USB flash drive to recover administrator password. Booting up and clearing a password takes a minute or two works like a charm.
more info: http://www.windowsloginrecovery.com
Posted on Feb 20, 2010
Tely Sanden
    Guru:
  • 204 Answers
Forgot windows vista password?Do not be so anxious. I know a tool which can help you bypass windows vista admin password, need not to reinstall the windows OS, its safely and easily.By using "Any Windows Password Recovery 3.0 " ,could be helpful.
Posted on Feb 08, 2010
Anonymous
There ant any way to solve this problem but u can reinstall Vista. if u want []to please feel free to contact me
Posted on Nov 08, 2009
3 Related Answers
Ekse
  • 13434 Answers
SOURCE: forgot password
let me know if you need assistance,
Posted on Mar 29, 2008
wuyibnuep
  • 171 Answers
SOURCE: hi, I have acer laptop with window vista on it ,forgot password
Try this:
1. Enter a computer that can link to Internet. Download a Vista password recovery tool (I recommend windows Password recovery Tool 3.0 ) and install it on that computer. Note that: there is a ISO image file. Burn the file into a CD or a USB flash drive.
2. Eject the created CD/USB and insert it into the locked computer.
3. Reboot the locked computer (it's necessary for you to change your computer's Setup to make it boot from CD drive or USB drive) and then followed the process of instructions. Just a few steps, the old password was removed.
4. Now login Windows Vista and set a new password.
Posted on Jan 21, 2011
Joe Allen
  • 14 Answers
SOURCE: forgot asus laptop password Windows vista
To reset your ASUS laptop Windows login password, I think you can try this password recovery software, fully compatible with Windows 7, Vista and XP etc operation system, supporting both 32-bit and 64-bit. You can do it on your own, no need to send it to a computer shop. Regards.
Posted on Nov 17, 2011
Tip
Forgot Windows Vista Password - How to Reset or Recover It?
No matter you use a Mac or PC, no matter your operating system is Windows 7, Windows Vista or Windows XP, computer security can be a common topic for you. For PC protection, a Windows password is often regarded as the first line of safeguard. But there is a little problem as Windows password can be easily forgotten. Forgetting Windows password could also be dangerous if your only have one windows account or others.<br /><br />In that case, you can use a password reset disk to reset or recover the forgotten Windows password. Here we introduce a simple tutorial for you when <a href="http://www.windowsloginrecovery.com/forgot-windows-vista-password.html">forgot Windows Vista password</a> - Burn a password reset CD/DVD with Windows Login Recovery. This method can be applied to all situations, no matter you can log on PC or locked out of computer.<br /><br />Windows Login Recovery enables you to create a password reset CD/DVD. When you forgot Windows Vista password, you can use the created CD/DVD to reset the forgotten password in just 3 simple steps:<br /><br /><span style="font-weight: bold;">Step 1: Burn a password reset CD/DVD.</span><br /><br />1. Run the program and insert a blank CD/DVD to computer.<br /><br />2. Select to Reset Local account password, and click Next.<br /><br />3. Select CD/DVD and click Burn to start burning the CD/DVD.<br /><br />4. Click OK when the CD/DVD is burned and take it out of computer.<br /><br /><span style="font-weight: bold;">Step 2: Set your locked computer to boot from CD/DVD.</span><br /><br />1. Insert the burned CD/DVD in the locked computer that you forgot Windows Vista password.<br /><br />2. Press F2, Delete or F10 to enter your BIOS Setup when the computer is booting.<br /><br />3. Choose Boot on the taskbar, select Boot Device Priority and press Enter.<br /><br />4. Make the computer to boot from CD ROM firstly according to the prompts on the right.<br /><br />5. Press F10 to save settings and your computer will restart automatically.<br /><br /><span style="font-weight: bold;">Step 3: Reset forgotten Windows Vista password.</span><br /><br />After restarting, you can reset Windows administrator password and standard user password under DOS.<br /><br />1. Choose the installation path of Windows, and enter the NO. of the path.<br /><br />2. All Windows account user names will be displayed for you. Enter the NO. of a specified User Name to remove its account password.<br /><br />3. Enter y to confirm and continue your operation.<br /><br />4. Enter y to remove another Windows account password or enter n to finish your operation when the selected windows account password is removed.<br /><br />5. Take the burned CD/DVD out of computer and press any key to restart your computer when you enter n to finish your operation.<br /><br />The password has been successfully reset and now you can log on your computer without password.<br /><br /><span style="font-weight: bold;">Notices for Windows Vista password reset</span><br /><br />1. When you forgot Windows Vista password and locked out of PC, with Windows Login Recovery, you can create a password reset CD/DVD in any accessible computer with any OS, like Windows 7/Vista/XP and Windows Server 2008/2003/2000.<br /><br />2. The computer used to install the program should have a CD/DVD burner; both internal and external CD/DVD burners are OK.<br /><br />3. After <a href="http://www.windowsloginrecovery.com/windows-vista-password-recovery.html">Windows Vista password reset</a>, no computer data will be lost.<br /><br />4. This method can not only help you when you forgot Windows Vista password, but also help you regain access to computer when you forgot Windows passwords on Windows 7, Windows XP and so on.
on Nov 11, 2010 | Computers & Internet
SmartkeyWindows Password Recovery f is an easy-to-use tool designed for resetting Windows local administrator password or domain password on any Windows system. If you have forgotten your password, or are locked out, or you do not have access to the password of the system. It is the most effective product on the market. with a Graphical background and it is the easiest solution for Home Users and the overall Best for Businesses. You only need to boot from Windows Password Recovery CD/DVD, and reset forgotten vista password to Blank . Then you can get back into your system with blank password. No need to call a technician, no need to re-install anything, and you certainly don't need to reformat.
May 25, 2012 | Lenovo 3000 N500 Notebook
Hi i forgot password. laptop wont get into system, it jus prompts for password after boot
To reset your BIOS password you have four options you can read about here http://www.fixya.com/support/r7229632-reset_or_remove_bios_password
If it is in Windows try one of the following:
- see this for XP http://support.microsoft.com/kb/321305
- or this for Vista/Win7 http://windows.microsoft.com/en-us/windows-vista/What-to-do-if-you-forget-your-Windows-password
- or if anything else didn't work you can use thrid party software from Hiren's Boot CD http://www.hirensbootcd.org/download/Hirens.BootCD.12.0.zip
Dec 13, 2010 | Acer Aspire 5536-5224 Notebook
Forgot my windows vista login password and do not have a reset disk
my orcut is not opening password and email id is correct but taking time and its not opening
Feb 27, 2010 | Microsoft Windows Vista Home Premium...
Forgot password
If you did not create a password reset disk you need a technician to do this for you. If there is another user on the computer you can remove the password from the control panel using there account.
Feb 23, 2010 | Microsoft Windows Vista Ultimate Edition
Forgot my windows vista login password?
How to access Windows Vista without reset disk?
Reference to:
Forgot Windows 7 Password and No Reset Disk - How to Get in?
This passage is mainly about how to reset Windows 7 forgotten password without reset disk, but it is also applied to Windows Vista.
Another administrator, Windows install CD, Ophcrack and Windows Password Genius can be used to reset Windows 7 forgotten password.
Jan 02, 2010 | Dell Computers & Internet
Forgot password for vista login
If you forgot the windows login password and want to recover or reset windows password, there is two methods to reset windows login password:
Methods 1: Use the password reset disk to recover the Windows password, by this methods, you need create a Windows password reset disk before you have lost or forgotten your Windows admin password.
Method 2: Using Windows Password Recovery software to recover Windows password
As an easy method to recover the forgotten Windows password, there are only four steps as follow:
Step1: Download Anmosoft Windows Password Reset V8.0( http://www.resetwindowspassword.com
)and install it.
Step2: Burn the ISO image file onto a blank CD/DVD or USB.
Step3: Boot up your Windows PC by the bootable burned CD/DVD or USB in minutes.
Step4: Remove the forgotten Windows password on the operation interface and logon PC without password.
Jul 08, 2008 | HP Pavilion dv6000z Notebook
HP Pavillion ZV6000 Notebook Logo
605 people viewed this question
Top HP Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
efs_perpends
efs_perpends
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
