Question about Dell 0Y3740 Keyboard
The C V H T and B keys on my other Dell laptop, an Inspiron 1545 have stopped working
Posted by babba157 on
Anonymous
    New Friend:
  • 34 Answers
Remove Any Docking Stations or Port Replicators From the Computer Note: Docking stations and port replicators are optional equipment. If you are unsure if you have a docking solution attached to your computer, refer to Table 1 and Table 2 for examples. To remove the docking station or port replicator, perform the following steps: Shut down the computer. Remove the docking station: Universal Docking Stations: Disconnect the docking station's USB cable from the computer. D/Port or D/Dock: Remove any cable locks from the security slot on the right side of the docking station. Move the slide lock forward to the unlocked position. Press the Eject button and lift the computer from the docking station. C/Port II or C/Dock II: Remove any cable locks from the security slot on the left side of the docking station. Pull the locking lever forward until it stops to eject the computer, then slide the computer out of the docking station. Dell manufactures the following docking stations and port replicators (Table 1): D-series DocksC-series DocksSpecialty Docks D/PortLatitude? C/Port IIMedia Bases D/DockLatitude? C/Dock IIInspiron? Advanced Port Replicator Table 1: Dell Docking Stations (Click an image to enlarge it) Universal docking solutions are also available from third-party manufacturers including, but not limited to, the products below (Table 2): TargusKensingtonBelkin Table 2: Universal Docking Solutions (Click an image to enlarge it) Reseat the Keyboard Connector to the Motherboard Caution: Before performing any of the procedures in this section, read and follow the safety instructions in Dell Knowledge Base Article: "Precautionary Measures for Personal Safety" Article ID: 339031. Reseat the keyboard connector to the motherboard. Be sure to handle only the connector and not the cable. For information about how to open the chassis and remove, reseat, and replace components, please refer to your Online User's Guide and browse to the Replacing and Removing Parts section. Remove All Power Sources and Reset the Computer Remove the battery and disconnect the AC power adapter from the computer. Note: For information about how to open the chassis and remove, reseat, and replace components, refer to the Online User's Guide. Click Systems, then the make and model of the computer. Download the Owner's Manual or User's Guide and refer to the Adding and Replacing Parts section. Press and hold the power button for 10 seconds. Reattach the AC power adapter to the computer. Power the computer on. Replace the Internal Keyboard
Posted on Nov 07, 2009
  • ibenadars_ma Dec 28, 2010
    This is not a solution to the problem, it is not a faulty keyboard issue, but something else. I have the same issue and the 4 keys CVTH always work with SHIFT and sometimes they do not when typing in certain text fields. URL bars = no, Vista search bar = NO, this text window = yes.
  • Not a solution. I have the same issue. I have to restart the process with the issue to have it work again. This is a Windows issue, not a keyboard one.
1 Related Answer
Anonymous
SOURCE: Dell Inspiron 1545 laptop keyboard cursor jumps to
Go to http://support.euro.dell.com/support/index.aspx?c=uk&cs=ukdhs1&l=en&s=dhs
Click the drivers and downloads section.
Enter your service tag number and procced to the download section.
Click Input Device Driver and dowload the alps touchpad exe file. Run this and your problems will be solved.
Posted on Oct 28, 2009
My inspiron 1545 types two letters at once
On most laptops there is a function key that will lock the keyboard.
You would need to pres the [Fn] key and the appropriate [F#] key. In mine the combination
would be [Fn+F1] keys. If you shut down to re-activate the keyboard you will loose whatever you are working on.
hope this helps
I have a Dell Inspiron 1545 and one day the three keys 'i', 'o' and 'p' randomly stopped working. What can be the problem? Can I fix it myself?
Try checking the keys in Command Prompt
Go to Start
type CMD in RUN
and type the keys and check if they work
If not go to device Manager
Steps
Click on Start
Type device Manager in Search Program and Files.
There will be a List and find Keyboard
Expand the Option
You will get the driver of Keyboard.
Right Click on it and click on uninstall.
Once uninstalled the driver will go away
Restart the PC once you reach the desktop it will automatically install the driver.
You will get the notification of driver installed.
It it installs successfully try using the keys that are not working.
Hope it helps
1helpful
My ESC and F4 key not working on Dell Inspiron 1545. What should i do. Please i need your help.
Please clean the keyboard and try to whether the keys are working or not. If possible you can use external USB MINI keyboard..
1helpful
Dell inspiron 1545 laptop (Time- of- date clock
This could mean two things: a problem with the cmos battery or the motherboard itself. Try to remove the cmos battery first and install. If not,then replace the cmos battery.
7helpful
2answers
Dell Inspiron 1545 Broken Screen?
The LCD is definitely shattered, looks like pressure was applied from the back of the screen (Pressed on, laid on etc) and the LCD will need to be replaced.
Several are available on Ebay
http://shop.ebay.com/?_from=R40&_trksid=p3907.m38.l1313&_nkw=Inspiron+1545+LCD&_sacat=See-All-Categories
Service instructions are here
http://support.dell.com/support/edocs/systems/ins1545/en/SM/display.htm#wp1183775
No power to dell inspiron 1545 adapter
Ya this is a AC adapter Failure if there is no blue light then ,if you have any other known good AC adapter to try with if it works then it faulty call DELL with see whether your system is in warranty, there is 20 digit long serial no on the dell ac adapter,they will replace it if it is in warranty
Laptop keyboard stopped working,odd keys stoped working now nothing works. Operates with vista
Software Failure
if your are able to get to bios screen using " F2 "key...
Try safe mode
uninstall usb controllers from device manager
Last option OSRI
Hardware Failure
Recommend you to run PSA Daignostics.
1helpful
I have a Dell Inspiron 1545 and when I type, sometimes the key works and sometimes it doesn't. It's not limited to any particular key but all. Writing an email is all but out. This is my second computer...
Call them back and keep complaining. Eventually they'll probably end up upgrading you to better model.
The only time I've seen that problem it's been hardware related.
Hope this helps.
I have a dell inspiron 1545 and the keys randomly don't work. I will type and letters will not work unless you press really hard! Very frustrating, waht to do?
Generally, the best resolution is replace the keyboard. Simple process and keyboards are usually available on EBay for less than $40
Dell 0Y3740 Keyboard Logo
Ekse
Mandeep  Singh
Mandeep Singh
Michael Thomas
Michael Thomas
