Question about Crate Blackheart BH5-112 Little Giant Guitar Amp Combo, 5W All Tube with Attitude
Zero output, no noise, no hum, no nothing I've tested with various speakers I've checked the fuses I've check the power tranny I've changed the tubes.
Posted by guitars958 on
Rommel Cana
  • 5,807 Answers
Then you may need to measure plate voltages
there is a possibility of open resistors or changed- value
Posted on Nov 07, 2009
  • 1 more comment
  • Rommel Cana
    Rommel Cana Nov 07, 2009
    here is a simple guide:
  • Rommel Cana
    a) you can inject audio with a series capacitor on the blue arrow., to test the main amp
    if there is no sound , have a resistance check on the resistors ( orange arrow)
    need to measure the B+, should have at least 250V
    b) if there is audio on blue arrow then trace circuits backwards going to the input.
    it might take about 5 minutes for the tubes to warm up and to produce sound on the speakers
  • Rommel Cana
    Rommel Cana Nov 09, 2009
    when having a resistance check,
    unplugged the unit and safer to discharge first the filter capacitor with a 4.7K 5W resistor.
    if your having trouble reading the resistor color coding, post the colors and will decipher it for you.
    you can use an analog multimeter or either a digital one , both is OK
My peavy escort 1500 keeps shutting off but will come back on if I turn it off and on is it a fuse?
Can't be fuses, as it comes back on!
Questions:-
i) Does it go off when run continuously with volume controls at zero?
(this checks whether the audio output level is causing a problem).
ii) When the unit does operate, is the sound good on both speakers?
iii) Does the fault occur more when outdoors (wind noise tripping the power protection). If so, reduce the low freq EQ setting.
iii) Do the EQ lights flutter when the fault occurs?
This fault has been reported on the Escort 3000 too, see link
Peavey Escort 3000 sound cutting out - Peavey Forum
suggesting this may need a 'electronic modification' to put it right.
Hope this helps.
Dec 30, 2014 | Music
I have a Crate CR212 it started to hum/buzz today. It would not play out any sounds other than the noise. I unplugged everything and still it hummed. I unplugged the unit, check the fuse and replugged and...
Are all the tubes lighting up? they should glow like dim light bulbs. If not, replace them with the same model type (12ax7, or EL34 for example).
Often there are two fuses, one to protect the speaker and another to protect everything, it sounds like the latter fuse may be burned out. take it out and take it to radio Shack for exact replacement.
Oct 12, 2013 | Crate Music
After a gig last night we tried our Marshall JCM 2000 DSL401and it had developed two noises without anything plugged in. The first is a transformer hum that I'd never noticed before and when standby is...
Likely the filter capacitors have a problem. Best to take this in for repair... it is ODD that there is noise with the standby switch is in standby... That makes no sense... In standby it appears that power is removed from the power amp high voltage so nothing should come through the speaker... Unles maybe one off the power tubes had a total meltdown which should have blown the fuse.
Sep 10, 2011 | Marshall Amplification Marshall Cover For...
Power dont *** on
It is possible that the amplifier had encountered a fault with a higher current drain which had triggered it to a protection fault condition. The fault can be your output drivers- the MOSFETS/IC's fitted for both the channels, Use a meter after disconnecting to check for short in the drivers. Disconnect the positive and negative voltages to the output and see if the protect changes. Even a fault in the preamp stages that drives in high current into the output can shut the Amplifier. Sometimes this can be a noise like a HUM or HISS before the protect works. Faulty capacitors in these circuits also can cause similar issues and needs close observation.
You need to confirm and replace the specific stages or outputs. If not there can be issues in the mother board, maybe the protect circuit by itself is shutting off due to a faulty bias , maybe a leak in any voltage/current sensing circuit. Also disconnect the speakers and test, if the protect is off then check for short on the speakers.
Aug 08, 2011 | Fender Squier 4-channel Travel PA...
Have a low noise like hum when i turn on thump 15A It doesn t change by moving level but when I plug in anything it s feeding a noisy tale on every signal attack.
Make sure you are using BALANCED audio line to the speaker AND your mixer is powered from the SAME receptacle as this speaker. One MAY have to run an extension cord back to the mixer and othe equipment, but this must be done to reduce noise and also for equipment safety. Multiple recepatacles in a building have grounding issues that can generate noise or worse damage equipment due to ground loops. If you DJ mixer does NOT have balanced outputs, use DI boxes so you can use balanced lines to your speakers. Your cables will either be XLR or 1/4 inch TRS types, not just TS type.
May 14, 2011 | Mackie TH-15A Active DJ Powered THUMP...
One speaker hums very loud with nothing plugged into it i own the mr-8
If this monitor is humming without nothing connected to it, maybe the electrolytic capacitors from its power supply are bad - they are responsible for filtering the fluctuation at the output of the internal voltage rectifiers that transform the AC input voltage into a DC voltage to feed its internal amplifier.
When they fail, the supply voltage for its internal amplifier that should be flat, continuous, now presents a pulsating profile, according to the mains frequency (generally 60 or 50 Hz, depending on the country you're in). So, the output of the amplifier will be varying at the same rate, producing the humming.
Another possibility is that one internal cable connection that should be shielded is now disconnected or loose and is picking the hum from the internal power supply.
Anyway, maybe you should take it to a service center and have it checked.
Hope this info may help you!
Mar 11, 2011 | Mackie MR8 150W 8 Active Two-Way Studio...
My amp has output but no sound from the speaker.
If you have tested with other speakers, you may have blown the ones that are not working. Test the speaker(s) on another source. I am not sure how you have tested your amp that it "has output"... indicators mean NOTHING on the amps as far as actual power going out.
Jan 29, 2011 | Hartke Ha2500 250watt Bass Amplifier Head
When i power up my line 6 spider 3 ( i think it has two 75 watt speakers) all the lights work but no sound at all no static or speaker sound even at full volume. cable checks out, but even with a bad cable...
A pilot light means almost nothing other than the power cord is plugged in and hot and the switch is on. In this case, other lights run from various DC supplies so the inout fuse is presumed to be good... NEVER replace a fuse without knowing what caused it to blow or you will usually do more damage within a unit. There are several power supplies and you will typiclly find +/-15 volts on the op amps and 3.3 volts on the processor logic. Unless something simple like the speaker cable falling off this will NOT be a DIY repair. I would look to see if this speaker cable might have fallen off and ALSO check if you get any sound using headphones.
Nov 06, 2010 | Line 6 Spider Iii 120 Stereo Guitar Combo...
Yamaha pt300. was working fine. Now only makes loud humming noise which doesn't repsond to change in volume. Monitor display shows keys register as being played, but no sound can be heard except loud...
Likely the power adapter has failed if it uses one. Try a new one first.
If half the rectifier blows out, a very impure DC voltage is applied which will be heard in the audio output.
Sep 27, 2009 | Dean Dimeblade Tribute Electric Guitar
NO sound through the AMP even though the power light comes on
Not a fuse. First thing, to check your speaker (amp unplugged, of course), touch the + and - speaker connections to a 9V battery. If you don't hear a pop sound then your speaker is blown. Thus, no output sound. If speaker is OK, then the output IC is your problem.
Jul 12, 2009 | Music
Crate Blackheart BH5-112 Little Giant Guitar Amp Combo, 5W All Tube with Attitude Logo
75 people viewed this question
Top Crate Music Experts
Ngoro
ray gallant
Are you a Crate Music Expert? Answer questions, earn points and help others
