I have no problem with the boot size or din setting but is there a general rule for the vertical setting on the front binding?
I recently bought the skis second hand and am incapable of purchasing anything without totally dismantling whatever it may be! So here i am searching for a little advice before i tear a tendon!
Am probably top end of intermediate skiing capability if that helps,
Alor, any info would be much appreciated
Cheers
If you can adjust vertical pressure then you should adjust it as follows.
Put a piece of normal paper (like A4 printer paper) on the toe bit (and heel for that matter) and clip in the boot so that the paper sits between the boot sole and the binding base surface. You should be able to pull the paper out from between the boot and binding without ripping the paper, but obviously without there being a noticeable gap.
If in doubt take it to a ski tech, a bit of cash might save you a broken leg! They might even be able to help you or advise free of charge.
