My tv turns on but I see a black screen with a key at the bottom
Posted by mauriceba849 on
Anonymous
  • 36 Answers
Sounds like it is in hotel mode,i need the modle/make of the tv befor we can proceed.
Posted on Nov 07, 2009
2helpful
2answers
When you turn the TV on the screen splits in two,
it sounds like one of your buffer boards are going bad. these are the boards that help put the picture on the screen. there are 2 boards an upper and a lower board. if you remove one and turn the tv on you will get half a screen. see then if you get the lines. please leave rating after you check.
1helpful
2answers
While watching tv half the screen goes black
Download software from the Phillips web site. Use a usb flashdrive to transfer the download to the TV. This worked well for us and our picture is better than ever.
I have a 26inch Console Zenith Color TV, when I turn it on, I get a full pidture and sound but after 30 seconds, about 6-10 inches of the bottom screen goes black--but the rest is ok???
Get the remote control and press the MENU key repeatedly until you see the Video menu at the bottom of the list of options you will see EZ Picture.
Use the up/down arrow keys to select EZ Picture and use the left/right arrow keys to select your preference. Set the preference to Preset not custom.
Press Enter, Quit or Menu to exit. See if resetting the TV's Picture settings resolves the problem.
If you have a bar at the top of the screen as well then it could be in letterbox viewing mode. Again just go into the Video menu and turn it off.
Please let me know how you get on.
Good luck.
The bottom third of the screen has turned to black
Possibly the HOT (horizontal output transistor). When this goes out (slowly usually!), the screen gets eaten up by a black hole!
Tv locked
Enter all Zeros, if that does not work try 1234 or 9999.
Thank you for using Fix Ya!
Good Luck!
If you have any other questions, just let me know!
Don't forget to rate the overall satisfaction of this solution.
5helpful
Visio LCD TV - Partial Picture blacked.
Hello! I have a 32" Vizio LCD...within 30 minutes of the tv being turned on, black lines start running through the bottom half of the screen and eventually blacking out the bottom half of the tv screen. It also doesn't have anything to do with the ratio as I have tried that. HELP!
1helpful
2answers
Screen is blank with sound working
i just fixed mine by doing this. on the remote there should be a button that says f. hold down the f button then press mute and that should work it did for me
Televison & Video Logo
Top Televison & Video Experts
Ekse
