Question about RCA F27450 27" TV
I have a rca f27450 chassis atc 113.it has deloped a vertical problem.the bottom 30% is the only visible part.lost top 70%.any help is appreciated
  • Anonymous Feb 10, 2010
    correction.it is a total vertical collapse.
Anonymous
    New Friend:
  • 145 Answers
Yes. easy. you have a bad capacitor in vertical circuit. most common are the little red capaictors 2.2 microfarad. there is also a red capacitor 2.2 by the signal processor
Posted on Nov 14, 2009
Model rca p56830bl top and bottom of Pix is concave , and convergance is miles out any help is appreciated.John
ok, you asked, ON THE BACK OF THE SET IS THE CHASSIS NUMBER PTK195?
All RCA/GE sets have a chassis number on the back.
I am available of course for paid questions. Is it 195 chassis or not?
SD TECH
Sep 21, 2011 | RCA P56830BL 56" Rear Projection...
I lost the manual of the control, is rca universal remote control, and the tv is rca, i don`t know how to program it..ty
The codes for your tv are, 005,014,015,018,019,036,041,049,053,075,076,077,087,103,114,212,216,223,228,229,233,231,235,236,237,..turn tv on press and hold tv button till blinks,enter one of the numbers above,press power off, if tv turns off, that would be the code,..may have to repeat the steps with another number if not,...hope this helps...
Mar 15, 2010 | RCA F27450 27" TV
Won't turn on-flashes 3 times.
Flyback and or CP150 are the most likely two components to cause that symptom. If you need more info let me know and also post the chassis number off the rear tag as that model used both ITC and ATC chassis numbers.
Mar 13, 2009 | RCA HD52W59 HDTV Projection Television
No audio RCA F27450 27"
this is a very old problem.
dont break that tv. the amplifier is not working.
change the audio amplifier IC in your tv
okay
Dec 09, 2008 | RCA F27450 27" TV
RCA picture problem
Hi
This is vertical issue, your unit have problem in vertical section. this is Changed Value resistor, this needs to replaced a new one.
Thanks!
Nov 28, 2008 | Televison & Video
RCA tru flat 27 tv problem
the capacitor of vertical section is problem of your tv,so replace the capacitor value 100/50volts in or else all capacitors in vertical section.
Oct 14, 2008 | RCA TruFlat 27F520T 27" TV
Picture flipping
The P52940 uses the 195 series chassis. The vert/hgt control is for vertical height. It adjusts the size of the picture from top to bottom. If your picture is flipping, it most likely means that something is wrong in the vertical circuits. I have seen fluid leak out of one of the CRTs and drip down on the vertical output IC, causeing the picture to go crazy vertically. The set should be serviced by a qualified tech experienced in the RCA 195 chassis.
Aug 18, 2007 | RCA P52940 52" Rear Projection Television
Screen on rca tv compressed into 2 inch line in middle
The 20F530T uses the relatively newer ITC008 chassis. If the picture collapses down and only a small bright line is visible, it means that your vertical output IC has stopped working correctly. This could be due to a defective IC, cracked solder joints on the IC or the power supply that feeds it. The IC should be replaced or resoldered and/or the vertical power supply restored by an experienced tech familiar with the new line of RCA TV's.
Aug 10, 2007 | RCA 20F530T 20" TV
RCA F27450 27" TV Logo
106 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
