Computers & Internet Logo
Posted on Nov 07, 2009
Soyo SY-7VMA-B -supports P-3 tualatin (.13u) CPU's?
Soyo SY-7VMA-B motherboard (socket 370)- does it support the ''tualatin'' (.13 micron die technology) family of Pentium III processors?
I don't have the manual, Soyo is out of business ant their website is NLA
Anonymous
Level 1:
Problem Solver:
  • Contributor 4 Answers
  • Posted on Nov 08, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
Questions
Helped
2733
Points
8
When looking for a cpu for the socket 370, be sure to NOT get the socket 370 cpu that is made for servers.
this type requires a motherboard made specifically for that type cpu.
use a search engine to find out how to tell if it is a socket 370 server CPU, there is not enough space here for me to explain it.
in that search you will also find out how to determine the answer to your question about cpu's supported by that motherboard..
most socket 370 based systems run pretty well, so you have a good machine there, and it's worth your time to keep it running, and to upgrade it.
Drivers 7vba-2aa5
Hello the drivers from this site should fit your mainboard:
http://global.aopen.com/products_download.aspx?sDropDownProd=52
Please unzip the files bofore you install.
Install the 4 in 1 chipset driver first and reboot.
Install next the sound driver.
Here is also the VIA site:
http://www.via.com.tw/en/support/drivers.jsp
Here is some info:
SY-7VBA 133
Description
- 66/100/133 MHz FSB FC-PGA 370 Based ATX Motherboard
Processor
- FC-PGA 370 Pentium III Processors with 100/133MHz FSB
- Socket 370 for Celeron Processors with 66/100MHz FSB
Chipset
- VIA 693A + 686A Chipset
- 66/100/133MHz CPU FSB
System Memory
- Three 168-pin SDRAM DIMM sockets support up to 1.5GB
- PC133/PC100 DIMM support
- Provides ECC (Error Checking Correction) capability
On Board Audio Subsystem
- AC97 CODEC on board to provide audio solution.
SOYO has closed there support site many years ago.
Good luck
2helpful
Upgrade the 1.6GHz CPU on L7VMM2 Motherboard
ECS Support > L7VMM2 motherboard > Main Support page,
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=419&CategoryID=1&MenuID=50&LanID=0
Click on the CPU tab.
(Features / Specification / Download / Support / FAQ / CPU / etc)
Will support Up To an AMD Athlon XP 2600+,
http://en.wikipedia.org/wiki/List_of_AMD_Athlon_XP_microprocessors
Maximum Front Side Bus support is 266Megahertz.
(Max FSB = 266MHz)
(Motherboard manual states 133MHz.
Note that AMD processors are 'Double-pumped'.
This = 266MHz )
Supports AMD Athlon, AMD Athlon XP, and AMD Duron, processors.
Note in the CPU Support chart where it states -
Socket 462 > AMD Athlon XP > 2600+ (.13u)
The .13u stands for 130nm core architecture technology.
(nm = NanoMeter.
1 Billionth of a Meter )
NOTE*
For the Socket 462 (Socket A) processors, the AMD Athlon XP models are the top of the line.
'Sempy', or Sempron processors are at the bottom.
Low L2 processor memory cache compared to Athlon XP or Duron models.
http://en.wikipedia.org/wiki/List_of_AMD_Duron_microprocessors
http://en.wikipedia.org/wiki/List_of_AMD_Sempron_microprocessors
http://www.cpu-world.com/
http://www.cpu-world.com/CPUs/K7/TYPE-Athlon%20XP.html
Regards,
joecoolvette
What are the functions of its parts?
1) Motherboard Diagram, (Proper computer speak for motherboard is Mainboard. I just use Mobo.
MOtherBOard)
http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg
2) Soyo SY-KT400 Dragon Ultra - motherboard diagram,
http://techreport.com/articles.x/4139
CPU = Central Processing Unit. Another term is Microprocessor, or simply Processor for short.
The 'Brain' of the computer.
The Processor sits in a processor socket.
The processor socket for the Soyo SY-KT400 is a Socket A. Also known as Socket 462.
http://en.wikipedia.org/wiki/Socket_462
The motherboard chipset is the Northbridge chip, and Southbridge chip.
The motherboard chipset for the Soyo SY-KT400 is the VIA KT400 - Northbridge chip, and the VIA VT8235 - Southbridge chip.
http://en.wikipedia.org/wiki/List_of_VIA_chipsets#Slot_A_and_Socket_A
The Northbridge chip handles the Faster capabilities of the computer.
The Northbridge chip determines what Processors can be supported, what Ram Memory can be supported, and High-Speed graphics.
High-Speed graphics being AGP and PCI Express, not a graphics card installed in a PCI slot, nor Integrated Graphics.
The Processor communicates with the Northbridge chip through the Front Side Bus. (FSB)
Think of the FSB as an 'Information Highway'.
The Northbridge chip communicates TO the Southbridge chip through the Internal Bus.
The Southbridge chip handles the Slower capabilities of the computer.
The Southbridge chip handles IDE, SATA, USB, Ethernet, Integrated Graphics, and the PCI bus.
(As in a graphics card installed in a PCI expansion slot, for one example)
Also handles information from the Super I/O chipset.
The Soyo SY-KT400 - Super I/O chipset is a VIA VT1211
There are 5 PCI slots. All connected to the PCI bus, which is connected to the Super I/O chipset.
Click on this link,
http://techreport.com/articles.x/4139/2
Scroll down a little bit to the photo of the Soyo SY-KT400 motherboard.
A) At the top middle is the Processor socket. White in color, rectangular in shape, square hole in the middle, and socket holes on it.
To the immediate left of the Processor socket are 8 Electrolytic Capacitors in a row.
These capacitors are Radial Aluminum Electrolytic Capacitors. (Used all over the motherboard)
These particular 8 are part of the motherboard voltage regulator circuit.
Specifically, voltage regulation for the Processor.
B) To the right of the Processor socket are three long Black Ram Memory slots. (Proper computer speak for Slot, is Bank. 3 Ram Memory Banks)
C) The Blue and the White connectors to the right of the Ram Memory slots are IDE connectors.
One for the Harddrive, the other one for the optical drive/s.
D) Underneath the Processor is the Northbridge chip. There is a clear fan sitting on it.
E) The large square Black chip with VIA on it, below the Ram Memory slots, and to the right of the purple PCI slots, is the Southbridge chip.
F) The 5 purple long slots are PCI expansion slots.
G) To the right of the bottom purple PCI slot is the CMOS battery.
H) Above the purple PCI slots is a brown AGP slot.
Uses AGP 8X graphics cards
No video on sy-7vma-b
No video on a mother board cane be a combination of a few things, here are my suggestions
Take all devices off memory, video and/or any other pci card. Boot up the system to see if there is a beep or audible alert, this usually sounds off when the correct hardware installed installed or installed correctly, thi is a good fast motherboard test.
1. remove memory and reinstall it
2. remove the video card and ensure it is seated in the AGPor Pci slot
power the machine up to see if you have video, if not then there might be an issue with either CPU or motherboard
List of cpu support for pga 370 motherbord
The 810E Micro-ATX can only support the following processors
Intel Pentium 3 / Celeron
SY-6IWM motherboard
Your motherboard is a slot 1 socket board that is Pentium II, Pentium III and Celeron compatible.
1helpful
2answers
Who is the mother board manufature for sy -p41 845pe? what type of cpu does sy -p41 845pe suport and speed range? the type of module, max support capacity and speed ranges? the type of chipsets? the type...
Processors
  • Supports all Socket 478 CPUs (400FSB & 533FSB)
Chipset
  • North bridge: Intel I845PE MCH
  • South bridge: Intel ICH4
System Memory
  • 3 x 184-pin DDR SDRAM
  • DDR200 / DDR266 / DDR333 support @ 2.5v
  • 3GB maximum system RAM
Slots
  • AGP slot, 4x AGP compliant (1.5v support only)
  • 6 x 32-bit PCI 33MHz slots
On-board peripherals - I/O
  • 1 floppy port supports 2 FDD
  • 3 Audio Jacks for the CMI9738 sound chipset
  • CMI9738 6-channel sound
  • Davicom 10/100 LAN (10/100 Mbit/s)
  • 2 USB2.0 ports and a further 4 available via headers
  • PS/2 ports
On-board IDE
  • An IDE controller on the ICH4 chipset provides IDE HDD/CD-ROM with PIO, Bus Master and Ultra DMA/100/66/ operation modes
  • Highpoint HPT371 RAID single-channel ATA133 RAID controller
  • Ultra DMA/ATA133, 100, 66, 33 operation modes
  • Supports up to 2 hard drives
  • Serial ATA support via the Marvell 88I8030 single-ATA bridge
  • Supports 1 S-ATA drive
BIOS & Voltages
  • FSB speeds of 100Mhz - 255Mhz (quad-pumped)
  • 1.1 - 1.85v Vcore adjustable in 0.025v increments
  • 2.5v - 2.8v Vmem adjustable in 0.1v increments
  • 1.5v - 1.8v VAGP adjustment
  • Fix AGP/PCI speeds and variable settings
CPU compatibility
This motherboard is not compatible with a Dual core processor since this is a old Motherboard a;ready and only supports Intel Celeron, Intel Pentium 4..
2answers
SOYO SY-7VBA133U cannot adjust CPU speed
Flashing the bios is the best idea to start with. This will upgrade to the newest bios, which normally adds more features and fixes some bugs.
There is a small chance that this motherboard just doesn't support overclocking, but the majority of them do.
Below is the link to soyo's site and downloads for your model number. There was 4 or 5 bios updates. I would get the newest one.
http://www.soyo.com/content/Downloads/155/&c=28&p=48&l=English
Hope this helps
1helpful
Sy-7vem soyo cpu upgrade
Most of the new boards will automatically detect the cpu speed. If possible set the bios to auto detect. Otherwise go to Soyo website and check the manual
Grand Canyon Tech
Grand Canyon Tech
