Question about OKI C5150n Led Printer
C5150: All color prints are extremely streaky and
C5150: All color prints are extremely streaky and colors way off. We haven't received any display messages indicating to replace any of the cartridges. Black prints okay. Would a bad fixer unit cause this problem?
    New Friend:
This happened to me. It was caused by a bad "oki compatable" color cartridge. One time it ruined my drum. It was always the yellow color. Decide which cartridge is printing streaky. Remove it, bang it on the inside of a large plastic garbage can. Clean it. Reinstall it . If it still prints streaky throw it befor you ruin the drum. Replace it.
Posted on Dec 23, 2009
6ya staff
SOURCE:
Streaky printing
I have replaced the color and black cartridge . I have cleaned it and it is still streaky printing. What do I do?
Dec 23, 2012 | Kodak Esp 3250 Allinone Multifunction ( ...
The printed pages are coming out really streaky. We have tried cleaning it, but no joy. Any advice?
Print a few pages. As they are printing open the cover. Remove the toner cartridge. Look down at the page that was being printed. If it is not "streaky" look at the fuser, it probably needs replacing.
If that page is "streaky" replace the toner cartridge.
Jan 22, 2010 | HP Color LaserJet 2600n Printer
Printing
if your problem is printer setup page in go
and select to the b & w print and ink setting
are dark print set and give your print page
problem is also
Sep 12, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
HP 1600 color laser printer--colors are out of sync
Check the following information please.
General print quality issues
Solving issues with color documents This section describes issues that can occur when you print in color. Color document issues Problem Cause Solution Only black is printing when the document should be printing in color.
c00659983.gif Color mode is not selected in your program or printer driver. Select color mode instead of grayscale mode. The correct printer driver might not be selected in the program. Select the correct printer driver. The device might not be correctly configured. Print a Configuration page.
One or more colors are not printing, or are inaccurate.
c00659984.gif Sealing tape might be on the print cartridges. Verify that the sealing tape has been completely removed from the print cartridges. The media might not meet HP specifications. Use a different paper, such as high-quality paper that is intended for color laser printers. The device might be operating in excessively humid conditions. Verify that the device environment is within humidity specifications. One or more print cartridges might be low. If you are using non-HP print cartridges, no messages appear on the device control panel or in the HP Toolbox. Replace any low print cartridges. The control panel is set for override. Replace low or empty print cartridges. A color is printing inconsistently after you load a new print cartridge.
c00659985.gif Another print cartridge might be low. If you are using a non-HP print cartridge, it might be low or empty but you will receive no indication. Remove the print cartridge for the color that is printing inconsistently and reinstall it. The control panel is set for override. Replace low or empty print cartridges. The colors on the printed page do not match the colors as they appear on the screen.
c00659986.gif The colors on your computer monitor might differ from the device output. Select Screen Match in the Color tab of the printer driver. If extremely light colors or extremely dark colors on screen are not printing, your software program might interpret extremely light colors as white or extremely dark colors as black. If possible, avoid using extremely light or extremely dark colors. The media might not meet HP specifications. Use a different paper, such as high-quality paper that is intended for color laser printers. The finish on the printed color page is inconsistent.
c00659987.gif The media might be too rough. Use a smooth paper or print media, such as a high-quality paper that is made for color laser printers. Generally, smoother media produces better results. Repetitive image defect ruler Use a repetitive image defect ruler to measure occurrences of repetitive image defects to help solve image quality problems. Place the ruler next to the first occurrence of the defect on the page. Find the distance between identical defects and see the Repetitive image defects table to identify the component that is causing the defect. Repetitive image defects Measurement Component 24.7 mm0.97 inch Developer sleeve 26.7 mm1.05 inches Charge roller 32.9 mm1.3 inches RS roller 37.7 mm1.48 inches Transfer roller 54.5 mm2.15 inches ETB rollers 56.6 mm2.22 inches Fuser sleeve 62.8 mm2.47 inches Pressure roller 75.4 mm2.97 inches OPC
Have a good evening
Jun 18, 2009 | HP LaserJet 1600 Printer
Printer output has shadows, blurring, streaks, lines, poor color
Seem like blocked hole(s) on the color print head...
Most likely if there is a deep clean option then do it (may need a few times to unblock a hole or never).
Also get the printer physically cleaned up if you can see dusts inside (vrtical lines on color bars).
Mar 20, 2009 | HP DeskJet 9800 InkJet Printer
Color Faded
This sounds like a typical Developer Drive failure. The Developer Drive for color is different that the black developer drive. This is why black can print fine, but colors are faint or non existant. see below,a recent bullitin about this exact issue from Dell. ( the ROS, is the printhead, and is located behind the 4 developers.
5100cn Printer
Print Quality Issue
1. Problem: - Color images are extremely faint or not produced, but black images are produced without any problem.
Resolution: - Replace Developer drive assembly (H6702) and clean ROS Window/Glass.
If you chose to persue this repair, you can probably find a replacement developer drive by doing either a google search for the part number listed ( H6702 ) or an ebay search for the same. We can also provide you with removal and replacement instructions.
Good Luck
Oct 19, 2008 | Dell 5100cn Laser Printer
Okidata C5150 Servicing
I just changed all my color cartridges but the color printing does not show the right color. Is there a way to calibrate the colors or check how each cartridge is working or not?
Aug 21, 2008 | OKI C5150n Led Printer
Streaky printing & too much magenta
I know how expensive they are I really do how old and is this printer used alot and is the colors being used alot?
Even Streaks in the full paint job that happened to me too! I went hi and lo in adobe and found that the low ink was the problem
35 and 15 geesh and photo paper lost in this mess. It was my problem and now I share it with you so the trade off yea it is all your's sorry good luck
Jun 29, 2008 | HP DeskJet 5740 InkJet Photo Printer
OKI C5150n Led Printer Logo
546 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Thomas F. Schneider
Ekse
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
