notreading in your question that the dryer isnt heating i will assume it is heating yet not dryer the clothes and have ya check for a blocked and or chrushed vent
If your Whirlpool electric dryer
is having trouble heating, you should check all of the thermostats, the
thermal cut-off, all fuses and the electric heating element for
continuity and proper connection.
If you have already cleaned the lint screen, have you checked the venting system? It is the 4" flexible hose that usually connects in the back of the dryer and leads all the way outdoors. Many times the vent is stopped up causing the dryer to overheat and run longer, maybe not even drying the clothes.
The timer is stripped inside and needs to be replaced. The cogged teeth are made of plastic and a tooth or two has broken off keeping the timer from moving while running
I would be REALLY suspicious of the exhaust vent. If the dryer is heating up and the drum is turning, it has to dry the clothes UNLESS there is no air going through the dryer. Disconnect the air outlet flexible plastic duct at the back of the unit, and turn it on. If there is no or very little air coming out, the inside of the unit will be plugged with lint. If there is lots of air coming out, the exhaust duct or the outside flapper will be plugged. Sometimes if the exhaust is routed through a cold space there will be so much condensation in the duct that it will droop and literally fill up with water.
This is likely the thermal fuse on the heating element. You can check it with an ohmmeter. Also clean out your venting, as this often causes it to blow. Hope this helps!
make sure you have a strong air flow from the dryer it self take hose off and run the unit it should force your hand away if not your dryer is stopped up you will have to take fan casing off and clean (the metal going to hole for vent hose) if you do go outside and make sure you vent outside is opening and free of lint also wash your lint filter with warm soapy water fabric sheets stop them up and cause longer drying time
