Kodak EASYSHARE 5300 All-In-One InkJet Printer Logo
Posted on Nov 07, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Kodak easyshare printer 5300 error code3501
Kodak easyshare printer 5300 error code 3501
Anonymous
Level 2:
  • Expert 262 Answers
  • Posted on Nov 08, 2009
Anonymous
Expert
Level 2:
Answers
262
Questions
0
Helped
98262
Points
747
3501 error code indicates that the printer access door is open(The door that you open to able to see the ink cartridges).
If you recieved this error code and yet printer access door is open try to reopen it and close it, then unplug the power cable of your printer for 10sec then Plug the power cable back.
You cannot do any task on your printer if you have this message 3501. if this isue not solve call kodak tech support toll free 1 800 421 6699
Michel Smith
Level 3:
  • Master 1,218 Answers
  • Posted on Jan 25, 2011
Michel Smith
Master
Level 3:
Answers
1218
Questions
Helped
795391
Points
2925
In normal printers, Printer error code "3501" occurs because the printer has been left open. Check your printer to see if this is the case, and simply close the lid. On the other hand, if the lid is closed, it might be a calibration issue. Your driver may be malfunctioning or out of date. This is more common in printers with scanning features. Open the driver and check its settings. They should be perfectly identical to the ones listed inside the manual. If you've lost the manual that was shipped along with your printer, just download another one from the manufacturer's site. Change any discrepancies. If it still registers an error, you have to either update the firmware or uninstall the previous driver and replace it with a new one.
http://www.fixya.com/support/t7698088-error_code_3501
On the Kodak ESP 5200 series what does a 3501 error mean? can it be fixed by a user? will new cartridges fix the problem?
Hi!
The 3501 error code means "acces door open"
Please be sure that the printer's acces door is well closed.
If this doesn't fix the problem, please do the following:
1. Turn the printer off by pressing the on/off button
2. Unplug the power cord
3. wait for 1 minute
4. plug the power cord back in
5. turn the printer on
Hope it helped.
Regards,
Bogdan
1helpful
I not only recieved the error 3501 but the top of the page only come out clear the rest fades, although i inserted new ink cartridges tonight. Why?
Hi crromeo,
Error 3501 indicates a hardware error. The only way to fix it is to it repaired if it's out of warranty or replaced if it's in-warranty. Bring it to a Kodak Service Center.
4helpful
What do error codes 3501 and 3502 mean?
One of the best ways to prevent Printer error code "3501" from happening is to install latest version of firmware. To update firmware manually you can place the calibration sheet over the scanner and press START button. You can then click the HELP icon and select Maintenance option. From there, select Firmware Upgrade option and follow the instructions given there to download the latest firmware version; free of cost.
I have a problem with the color faces are a pinkish color and i just put all new ink in also and i have error codes 3501 and 6203
There can be plenty of reasons behind Error code "6203". These error codes often get displayed during printer installation. It is often seen that 'Error code "6203" gets displayed mostly when the printed calibrated sheet is put into the tray for scanning purpose and push button is pressed.
http://www.fixya.com/support/t5951196-kodak_easy_share_5300_printer
2answers
The printer is saying error code 3501, the printer is printing in color but the colors are like they should be. They are very dull.
error 3501 is for the front access door open and you will get that msg number of times you open the front access door and dont worry about that error......if the printer is printing dull colours then try and clean the print head from the menu or from the home center clicking on the question mark in the top right and click on maintenance and then click on clean print head.....if you still have the same issue it could be a refilled ink or non kodak ink that you are using....if the ink is genuine kodak ink then contact kodak tech support as print head needs replacement.....let me know if this was helpful
2helpful
I have had error codes 3610 and 3501 and 3502 since installing my Kodak 5300 and I can not calibrate my print cartridges as it can not detect the calibration alighnment page
call kodak @ 1800 421 6699 . this is a problem e cant fix ourselves. but dont worry its jst a problem with the software of kodak. printer is fine
What do error codes 3501,3502,3515 mean?
1. im not exactly sure
2. from the factory?
3. call 1.800.421.6699
also, i think the codes are related to your printhead
2helpful
Printing every other line in different quality
Hardware error
Error Code 3501
Error Code 6203
Error Code 6203
Error Code 3501
2answers
Not printing
try to press and hold the copy and cancel button at the same time. It should take up a pice of paper and spit it out blank. then try to print again. if problems persist call the 1 800 235 6325 kodak support hotline
2helpful
3answers
Since installing my printer I have a error code of 3610 and 3501
Go to the Kodak.com website and follow their prompts to reach Customer Support for the AiO Printer(s).
Had similar issues with mine and they resolved my problem overnite by sending me a replacement part.
Top Kodak Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
