I had the same problem, and found that the culprit was that the small filter element. about the size of a dime, that sits arount the nozzle activator (pin that depresses the clean water nozzel) was clogged with "gunk", and prevented cleaning solution from flowing into the unit.. It is easy to remove with a pair of tweezers or needle nose pliars.. rise it under water and reseat in the unit. You shoudl be aboe to perform the whole process in under a minute. This has happend to me several times... and am surprised the filter is not mentioned in the manual.
http://www.bissell.com/parts/?id=9143&sc=part&partid=17048&cid=ccsocial
