Neff W5340X0 Washer Logo
Question about Neff W5340X0 Washer
My neff washer has error code f 18 on it
Karl Wright
    President:
  • 1,653 Answers
The F18 Error Means that you need to do the following
Posted on Nov 07, 2009
Testimonial: "thanls"
1helpful
Cause of Neff Induction Hob Error d4?
I can only confirm that the is no D4 Error shown anywhere. If Neff, the maker can't tell you what the error is, then surely no-one can. Very poor show. I think I would be cutting my losses and go back to a traditional cooktop from a different maker and pursue a legal case against Neff. They should change their name to 'Naff'.
NEFF appliances are among the most durable and reliable kitchen devices on the UK market. But every once in a while, a NEFF appliance will throw an error code for you to deal with.
When a fault code is displayed on your NEFF appliance, it indicates a problem, but not what that problem is or what has caused it. An appliance fault code simply detects and indicates the nature of the issue and provides the general area where investigations need to be carried out.
Bear in mind that on many occasions, your NEFF appliance will be in need of professional repair from a certified electrician to get guaranteed results.
So, if :
  • You have a problem with your NEFF appliance
  • You want to know what a specific error code means
  • You want to trace and correct faults in your NEFF appliance
Then, read on.
NEFF appliances fault codes and their importance Your NEFF appliance will indicate an error code if it has a problem. This will be shown on the digital display and will be a single letter followed by one or two numbers. You can use this appliance error code to help identify where the problem is occurring. The most common appliance fault codes are related to defective oven elements, drainage issues on washing machines, and blocked pumps in dishwashers.
A detailed look at NEFF appliance error codes
NEFF induction hob error codes The most common faults of a NEFF induction hob are:
  • The hob not starting up;
  • The hob shutting off during cooking;
  • The hob flashing after finishing cooking;
  • The hob making a noise;
  • Food isn't cooking evenly.
NEFF induction hob error codes that may help you locate the source of the problem are shown here:
  • F1 - Tnsuitable cookware is being used, or there's no cookware in the zone;
  • F2/F02/F4/F04- Tour appliance hasn't cooled down completely;
  • F8/F08 - If your hob has been working on high power for a long time, the timeout will activate;
  • E9 - There's an internal fault with your appliance electronics.
Bear in mind that most of the issues will require a certifed induction hob engineer to complete the job and fix your NEFF appliance.
Feb 03, 2022 • Neff Ovens
1helpful
My Neff integrated dish washer is displaying error code 9
Bosch and Neff machines generate the same error codes..
E9 is an overfill problem. It's putting to much water in and overfilling.
If you wanted to check yourself you will need to take off the inspection cover on the front and locate the pressure switch if it's at the front. If it's not then you will need to pull machine out and take off the side panels. When you have found the pressure switch it will have a thin hose going to it and it will be round and have a few wires on it. Take this hose off and blow hard through it to clear any muck out.
Refit the hose and retry machine. Hope this helps..
My dryer keeps giving an E 14 error code. Even after resetting it, it runs for about two minutes & flashes the code again. How can I fix this?
Bosch Washer Dryer ' Neff ' Siemens ' Integrated ' Error Codes
www.ukwhitegoods.co.uk/.../fault-codes/...fault-codes/3312-bosch-neff-s...
Jan 16, 2012 - Bosch, Neff and Siemens integrated washer dryer error codes and ... The error codes in this article pertain to integrated washer dryers ... E14 ...
how to mend it .com - error code E14?
howtomendit.com > Household Appliances, Washing Machines
Bosch washer/dryer wvti3240 stops wash and displays error code E14. Can anyone help please ? also a full list of the error codes applicable to this machine ..
Nov 03, 2015 • Dryers
8helpful
NEFF washer not starting. error code 3/flashing anti-crease butto
This may be a simple control fault that can be reset by unplugging for 5 minutes or switching the breaker switch off for five minutes also. if the five minute reset doesn't restore the machine to its original operational value, you will then need to replace the main control board in this unit. it has failed.
2answers
NEFF WASHING MACHINE
Error code e 10 means no cold fill.
Ensure that the water getting to the machine from the water supplies at the back. Check that the hoses are not bent or kinked and that the water tap is opened.
Try cutting power to the machine for ten minutes to reset the code.
If that does not work, then it is usually a faulty inlet valve stuck on closed on cold water.
Neff washer dryer has error code e06 and the water wont drain
same problem, just replaced pump and cleared all outlet/inlet pipes (passed water through unhindered, still throws E06 when I try to start.
Neff washing machine with error code 6
error code 6 is drainage fault if it takes longer than 6 minutes it times out and aborts programme check filter isnt blocked and impellor spins freely,if ok may need pump replaced they are not expensive,
hope this helps
1helpful
Neff W4380X is showing error code 01
error code 1 is usually not heating it will progress through rinse as heat is not called for, when moves to heat stage will stop at that point inexpensive part to replace.
Neff W4380 error or warning '03'
Hello there,
when the machine makes drowning sounds and beeps error dry (while trying to drin out) blow strongly into the drain pipe. It should result in a higher flow of water out the drain pipe and error 3 should go away.
Top Neff Washing Machines Experts
Marvin
Marvin
Tom Chichester
ADMIN Eric
ADMIN Eric
Are you a Neff Washing Machine Expert? Answer questions, earn points and help others
