Panasonic DMRs cannot be unlocked for muliti region simply by entering a code form the normal remote or front panle controls.
Panasonic machines require a special remote control in order to make them multi region. Panasonic dealers will unlock your machine for you but will charge you - this is expensive.
Alternatively, if you search eBay you will find devices that will unlock your machine that can be purchased or "rented", for considerably less than a dealer will charge.
Please follow the steps :
To change the player region code
1. Be sure players drive is empty (nodISC)
2. Enter following key sequence using remote control:
Enter, 6, >=10, <<, 00F2, Audio, 8, * requested region code here (1-8) *, Subtitle, 1
3. Player will reset and requested region code will be set.
- For example to set region code to 3 press: "Enter, 6, >=10, <<, 00F2, Audio, 8, 3, Subtitle, 1"
To set the player to RCE proof region free
Enter, 6, >=10, <<, 00F2, Audio, 8, 1, Subtitle, 4
3. Player will reset and set to "region-free" and "RCE-free" mode
To restore players factory region code
Enter, 6, >=10, <<, 00F2, Audio, 8, 9, Subtitle, 1
3. Player will reset and set to factory region code
Regards, Jay__mnb6
SOURCE: Looking for the regional code
Region codes are preset in the DVD unit. DVDs are encoded with a region code and are only playable if the DVD player is programmed with the same code as the DVD itself. If you want to play Australian DVDs, you will want to use code 4. There are 9 codes. Check below to find out what region each code is for:
http://en.wikipedia.org/wiki/DVD_region_code
You usually may only change a region code 3 times before it becomes permanent. You need to enter the menu-setup options in your DVD player and you'll want to look for "region code".
SOURCE: any1 know how to unlock Panasonic DMR-EX768EB to multi region??
Hi
Get an unlock device DMR-EX768 (never mind the EB) from www.genuinecopies and follow the instructions. On the handset the red square in the bottom row is the STOP/EJECT
Mark
Thanks for the info.....l'll see the dealer as its still under warranty and has been sold and advertised as being multi region.
