Ice-o-matic under the counter ice maker is working, but there is water in the bottom that is causing the ice to be wet. It appears not to be draining?
You will need to pull out what ice you have in the bin to get to the drain. Once you have done that, take a hose and force water thru the drain. You may have to snake the drain if is more than a build-up of ice. Once the drain is working, clean out the bin with ice machine cleaner and sanitizer. Restart the machine and make sure no water is dripping from the evaporator above. If there is, it needs to be cleaned.
