LG CRT TV Problem
My LG CRT Color TV shows blue screen only, but the sound comes clearly
Posted by saratjec on
Anonymous
  • 541 Answers
It sounds like your picture tube is either shorted at the blue gun or there is a blue drive problem. The blue driver transistor can short and cause the same problem. If it has little fine white lines as well, most likely it is the tube. Thanks for using fixya.
Posted on Nov 11, 2009
My Hyundai tv 74 cm The color it not show good
Nice big screen but CRTs are getting old So, if you can't set correct colors with your Hyundai it might have some serious issue with tube. Probably replacement might cost you more then a new new 27" Flat Panel. See some tutorial and info about bad color of CRT
Fix your own CRT Television Color Problem
How To Diagnose Bad CRT or LCD Monitor
http://www.electronicrepairguide.com/monitor-color-problem.html
LG M2762D 27 Inch Widescreen 1080p LCD TV Monitor Black
LG Electronics LG M2762D 27 FLATRON LCD TV widescreen 1080p FullHD HDTV...
RCA F27440 27 CRT TV
Samsung TXN 2798HF 27 Tantus CRT TV 1080i
Tv screen does not show blue color what can i do
Check all the solder terminals at its video output card;[CRT base card]. Check the soldering of the CRT base socket. A dry solder joint or an open color output transistor can cause this fault; provided the picture is there. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
The fault is technically called 'one color predominant screen'. Use this keyword to search the site.
4helpful
2answers
LG 700E CRT 17" monitor,
problem with the monitor Display cable. it is damaged.
Normally monitor will receive 3 colors red, green, Blue signals from CPU. If one cable i.e Red wire connection is missing in display cable which is connected to monitor, Red color image on monitor wil be replaced with other fade color.
So, need the replace the display cable or display connector!
Clear but only blue/green color
Do you have a component cable hooked up to the TV? (cable with RCA connections Green/Blue/Red/White/Red)
If so you want to check that the red cable is tightly connected to both ends (TV and whatever it is connected to).
Good Luck...
2answers
SONY TV MODEL # KP-65WV700 SER.# 9002706
Blue Gun is right side of TV if you look in TV from back side. Part number is as follows..
8-733-663-25 {CRT 07MVC62(B)-L} [KP-65WV700 ONLY]
TV shows red
It sounds as though the color settings have been altered or that the tv is going out. Assuming this is a crt unit, you might try adjusting the color or unplugging it for a few minutes.
Good Luck,
BB
Blue screen
Check the CRT.and then check if there is a loose solder on the whole board and also check the H-out..change the CRT socket which is Color White Connected to the Tube.
Grey Screen
Try the reset on the remote. Press this key twice to restore factory settings. The TV will automatically start Channel Search and clear all customized settings. These features will automatically reset: ? Picture/Sound Adjustments: Color, Tint, Contrast, Brightness, Sharpness, Color Enhancer, Tone, and Surround Sound ? Channel Memory ? Audio to Stereo ? Caption to OFF ? V-Guide to OFF ? Aspect Ratio to 4:3 (normal) ? Menu Language to English ? Sleep Timer (if previously set) ? Video to TV (if previously set) If desired, personal settings can be made again using the menu options
Lg 150 cm rear projection
this is the engine problem cause by the blue lcd inside the engine if you can find the blue lcd you still have to do the converion. by lg technician
4helpful
3answers
Sanyo DS32920 Blue Screen
My panasonic Tv pic suddenly turned into a blue color I can't see the pic any more just can hear the audio.....any solutions????
Televison & Video Logo
Top Televison & Video Experts
Ekse
