Question about eMachines T5048 PC Desktop
I need to format my emachine hard drive. I don't have a recovery cd but i do have a xp cd
Posted by trickyii on
Catalin Turcu
  • eMachines Master
  • 4,924 Answers
Http://www.emachines.com/support/product_support.html?cat=Desktops&subcat=T%20Series&model=T5048
here you will find all drivers for your emachine ...
so ..assuming that you do not have expiriance ...I will try to explain in short how to do it ...
just insert the cd ...( be sure ya have the cd key if needed..) ...restart and press del to enter bios for to change the boot order to boot first from cd ...or ...
you can press F8 at start and choose to boot from cd and enter ...it will boot one time from cd ..and enter windows set-up..
after inspecting your computer will load primary drivers ..and ask you for the agreement press F8 again to agree...
inm this moment it will scan for previous installations and will show findings ...this is the moment that you press esc for to not repair or any ...than choose the C partition ...and see that you have D for delete it ...than enter to continue and L to confirm ...than C to create again and enter to format ....CHOOSE TO FORMAT INTO ntfs MODE...QUICK OR NORMAL ...
If you didnt format it a lot it doesnt matter too much ..but normal NTFS will take longer to do it , but it has a better efect ...from now on it will load the files ..and restart to continue the installation ..
the other partitions just format them from the windows ...by right click them ...and choose format ..from the list of commands..
Posted on Nov 07, 2009
Argospete
    Genius:
  • 1,035 Answers
Click my computer, click computer C: drive/right click c drive up comes menu , click format.
when finished turn off/turn on. insert xp cd.
I take this cd is the full prog to install XP?
Remember you will lose all data!
Hooking up a Internal Hard drive
You probably need to give more details. If it's a replacement drive, did you reinstall Windows from a CD? Did you copy from the original hd? It's simple enough to remove the two cables from the original drive, physically remove and replace the drive, and hook up the new drive. But then you'd need to boot to a Windows CD in the CD/DVD player to format and install Windows, if that's what you're attempting to do.
There's possibly a recovery partition on the old drive )or a recovery CD). If so, you'd connect the new drive to a second power cable, and data cable (which might not be included in the tower) :
(from http://support.gateway.com/s/Manuals/Desktops/8510406.pdf)
To restore system software from the Recovery discs:
1 Insert the Recovery disc #1 into the CD or DVD drive.
2 Restart the computer, then press and hold
R when prompted to display the restore process options. The
Options menu appears.
3 Select a restore process option:
- Press R to boot from the hard drive recovery partition
or CD. If no recovery partition is found, go to Step 4.
- Press F to format the hard drive and perform a full system
recovery, then go to Step 5.
4 Click a system restore option. For more information, see
"Restoration options" on page 5.
- Non-Destructive System Restore (Recommended)
- Full System Restore (Destructive)
- Full System Restore (with Backup) (Advanced Option)
5 Follow the on-screen instructions to complete the system
software restoration process.
Oct 29, 2013 | eMachines ET183105 PC Desktop
EMachines ET1810-01 trying to install xp pro on clean hd, cmos does not show hard drive and xp says there is no hd. it is connected. how do i get it to find the hd?
You need to format your hard drive. Set your boot device to cdrom in your bios. Boot using xp cd.DO a reinstall of windows and it should give you the option to format or delete partitions on your hard drive. if that doesnt work try putting the hard drive in another computer to see if it works. Or you can buy a hard drive enclosure that allows you to use your hard drive as an external device.
Jun 11, 2010 | eMachines (ET181001) (A1803181 ON) PC...
Need to re boot my sons emachine e525 back to origional settings.don`t know how..no cd .
You'll need the Recovery CD for this. Try contacting emachines (www.emachines.com) and they should be able to sell you a duplicate of the CD.
Good Luck..
Feb 16, 2010 | E-Machines emachines (emachinees) CD-ROM...
Format WD laptop hard drive in Emachine laptop
Normally when u restore, formatting is being done at a certain step. Therefore no need to worry as the OS is included in the recovery. However if it's exactly how u r stating, therefore buy an external 2.5" HDD casing,insert ur HDD in it, plug it to the USB of any computer or laptop & get it formatted.
Feb 07, 2010 | E-Machines eMachines Desktop PC
EMachine T2778 new hard drive, restore disk aren't working, how do I format?
1st Option: Go to BIOS level and select the CD/DVD device is the first device for boot option and then insert the recovery CD/DVD to format or install OS.
2nd Option: If recovery CD/DVD got curropted and you are having the other OS CD/DVD, then try to load and format or install the OS. Also try to download the recovery image from vendor website.
Revert back for more assistance.
Jan 31, 2010 | E-Machines eMachines Desktop PC
My eMachines T3882 with Windows XP just reboots over and over
Sounds like a sick hard drive. When it starts to reboot, press F8 and choose Windows Diagnostic Test. It will show a hard drive failure if one exists. If it finds a hard drive error, the hard drive is junk and needs replacing. Once replaced, you can run your restore/recovery disk to install Windows back to the condition it was in when you bought it.
Dec 16, 2009 | E-Machines eMachines Desktop PC
Upgrading HDD From 40GB To 160 GB
  1. Use the Windows XP Setup disks to restart the computer, or use the Windows XP CD-ROM to restart the computer.
  2. At the Welcome to Setup screen, press R to repair the Windows XP installation.
  3. Press C to repair the Windows XP installation by using the Recovery Console.
  4. Type the number that corresponds to the Windows installation that you want to repair, and then press ENTER. For example, type 1, and then press ENTER.
  5. Type the Administrator password, and then press ENTER.
  6. Type map, and then press ENTER. Note the drive letter that is assigned to the CD-ROM drive that contains the Windows XP CD-ROM.
  7. Type the following commands, pressing ENTER after you type each one, where drive is the drive letter that you typed in step 4 of "Method 2: Use the Recovery Console," of this article: copy drive:\i386\ntldr c:\
    copy drive:\i386\ntdetect.com c:\If you are prompted to overwrite the file, type y, and then press ENTER.
Feb 19, 2009 | Western Digital 160GB Caviar ATA-100...
Emachine W3507----upgraded to windows vista----I want to do a full system restore
Most package systems like that will partition the hard drive and place the recovery image on the smaller partition of the drive. I don't know about this specific system/model, but I'd bet that is the case, and explains why you have no Recovery CD. Now, you need to understand that if you restore that image, it will be what the system had in place when you bought it two years ago. So, BACK UP YOUR DATA!! You will lose everything you have done for the last two years.
Now, having upgraded to Vista, there is no way to downgrade from Vista and end up with the XP you had before. You're going to have to format and start over. Did your computer come with a CD that allows you to boot and access the recovery partition on your hard drive?
Normally on systems like yours, you are prompted to create a restore disk when you first fire the system up. Did that happen with you? Did you create one?
Perhaps check this article on eldergeek: http://www.theeldergeek.com/re-enable_system_restore.htm
Jun 06, 2008 | E-Machines eMachines Desktop PC
Reformating the hard drive
high level format should appear as an option from recovery cd..
Apr 19, 2008 | Toshiba Satellite A45-S150 Notebook
eMachines T5048  PC Desktop Logo
957 people viewed this question
Top eMachines Computers & Internet Experts
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
