A CRT monitor just like a CRT television when it fails may still have a light on the front panel operate you probably had a catastrophic failure usually small electrolytic capacitors near the horizontal output transistor dry up an cause the transistor to fail the voltage regulator may also fail in the process
I assume the monitor is still plugged into the back of the system?
If so, do you get any beeps which can denote error codes for the system? Put your ear to the monitor, any strange whinning noise?
