Question about Olympus SP-350 Digital Camera
How do I transfer video to my pc?olympus sp-350
Posted by dreichert_78 on
5 Related Answers
Anonymous
SOURCE: Olympus SP-350 USB Device Not Reconized
Hi
You have to take out the card before you switch on the camera. Switch on the camera and then put in the card. Then it works
Posted on Jul 18, 2008
Anonymous
  • 33 Answers
SOURCE: Camera was dropped
The CCD could be damaged. It could cost nearly $200 to fix
Posted on Dec 31, 2008
Anonymous
  • 11967 Answers
SOURCE: my windows xp PC recognise camera Olympus sp-350
Forget the drivers...use a card reader.
Posted on Mar 31, 2010
Anonymous
  • 6831 Answers
SOURCE: Olympus SP-350 Digital Camera ZOOM ERROR
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Posted on Oct 07, 2010
hmerchant110
AliTech110
  • 7191 Answers
SOURCE: User Manual for an Olympus
You can download and print the instruction manuals in PDF format by clicking these links:
Basic Manual
Advanced Manual
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Hope this helps. Thanks for using FixYa.
Posted on Oct 14, 2010
Can I transfer memory picture to the SD card?
Probably, but why struggle, there's loads on ebay dead cheap hers's one:-
Item number: 230493049482
I havea an olympus sp-350, shutter is stuck so
I had the same problem, so tried putting the zoom fully on to take a picture.
It worked.
Sp 350,says software not recognoized by camera
It could be yet another glych with Vista. Try contacting the Microsoft website, and if there is not a specific patch available - email them.
The Olympus website may have something -
NEW DOWNLOADS FROM OLYMPUS
If this still does not work - Email Microsoft or Olympus directly, as you may not be the only one in this situation.
2answers
SP-350 WON'T FOCUS
unfortunately it is repair issue.. the lens does go out on a track and may have got off track
Olympus SP-350 Digital Camera card formatting
Try using this.
www.recuva.com
It might be able to recover your files.
SP 350 Olympus Camera
u may use the cd driver and reinstall it for the pc to recognize your camera
1helpful
SP 350
The answer to your problem might lie with the OS you are using. For whatever reason, when Microsoft brought out Vista it broke a lot of old programs and devices that worked perfectly fine. Why backwards compatability is beyond Microsoft, I don't know, but its an unfortunate circumstance.
Here is a link to Olympus' website, and a direct link to the SP-350 download page -
http://www.olympusamerica.com/cpg_section/software_results.asp?id=1188&os=w
I'm not sure if the drivers on the page are for Vista, its very vague but this is the first place to start.
Hi
Olympus SP-350 Digital Camera Logo
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Ekse
Are you an Olympus Camera Expert? Answer questions, earn points and help others
