My connection speed or signal is so very low and slow. It shows the connection speed at 11mbps. I have the Microsoft usb wireless adapter MN-510. It takes forever to get online and to get my email. How can I get a better signal and faster speed.
Given that you have a '802.11B' device, the maximum speed will be 11 Mbps.
While your wireless router is communicating at that speed to your computer, the router is communicating with your ISP at a much-lower speed, depending on how much you pay per month to your ISP for the agreed-upon level of service, e.g., "ADSL-lite" or "High-Speed".
So, unless you pay more per month to your ISP, the "bottleneck" will be between your ISP and your router, *NOT* between your router and your wireless adapter.
Now, as to the "low signal strength", that's a matter of the distance between the router and your computer, and the number and composition of the walls and ceilings in the middle.
If you move your computer closer to the router, the signal-strength should become "good" or "excellent".
If you are talking about about your speed while connected to the wireless, I do believe this is a 801.11b, which means it is a slower router (for wireless) and only goes up to 11Mbps. If you think you are getting even slower speed than that, log in to it, go to the wireless setting tab and find the setting for the connection speed. make sure its set to use the full 11Mbps! (sometimes is can be set to only 1-3 or 3-5Mbps).
If you are talking about the speed while connected via hard wire (eithernet cable), log in to your router and make sure that the wired speed is set to the highest value (I believe this one goes to 100Mbps full-duplex) and also make sure that the cable you are using is at least a CAT5 or above (CAT5. CAT5E, CAT6). A CAT3 ethernet cable will not go up to the 100mpbs! (this is printed on the wire).. also make sure that the port on your computer also goes up to 100mbps!
Makesure your computer is not too far away from your wireless router andyou have a good signal. By placing your mouse pointer over the wirelessconnection icon, located in the bottom right corner of your taskbar, you cancheck to see if your signal strength is good. Anything less than a good signalcan cause intermittent connections. SOLUTION:You will need to relocate your wireless router closer to your computer.
It's always difficult to troubleshoot wireless because the signal can be effected by so many different variables. Easiest thing would be to connect another wireless device. If that works OK then it's your computer or wireless adapter. If that drops out too then it's your wireless router. When we find out what's at fault we can find a more detailed solution if you' be kind enough to post back.
theres a million things that can interfer with wireless...tin...cell phones, cordless phones and the like..but 11mbps is still really fast and chances are, your internet connection isnt even half that so your speed on the net shouldnt be effected...1mbps is usualy enough to load any website in seconds.
if your PC is slow, not jsut on the internet but in general (starting up, running apps) then its an issue with the pc and not the wireless.
but as a heads up, not trying to be mean, but netgear and belkin are cheap equipment.
802.11b standard runs at 11Mbps. If you can only get 1Mbps from the router, you need to check your signal strength and your network card. If your wireless NIC in the laptop is only 802.11, you will max out at up to 2Mbps.
1. Try to use a different wireless adapter on all available USB ports, if the problem remains then
2. turn off your PC unplug the power cord from the power socket, short the two legs of the power cable then leave it for 5min, then plug it into the power socket again and turn on the PC.
if this didnt work then you have a hardware problem with the USB ports.
Try plugging the computer straight to the router.If all is well the adapter may need a firmware or driver update.Or your adapter may be experiencing some type of heat problem or failingRICHARDM69
If your connection without the router is only 30 mbps, the speed with which you will connect will never be greater than 30 mbps. Adding the router adds latency, so yes a router will always slow your internet connection slightly. 11 mbps is still pretty fast considering when you are downloading something from a website the average speed is about 270 kbps. My wireless router connects my laptop at 54 mbps, it is a wireless N router, which is faster than a wireless G. That could be another factor.
If you open up your wireless connection properties does it show having a full signal to the router? If the signal is low then that will cause slowness.
