If you wipe over the control panel while the hob is switched on, settings may be changed. To avoid this, the hob has a function you can use to lock the control panel for cleaning. To activate: Remove the twist knob. An audible signal sounds. The ? indicator and the hob settings flash. The control panel is locked for 10 minutes. You can now wipe over the surface of the control panel without altering the settings.
To deactivate: Put the twist knob back on within 10 minutes. The control panel is unlocked. To end the function early, put the twist knob back on before the 10 minutes have elapsed.
Hello. What the problem is a part in the cooktop that opens to let gas flow to the knobs as soon as they are turned on is bad and no gas coming to surface unit burners. This a safety feature that the German goverment(where Gaggenau is made) requires that part to prevent a gas leak when cooktop is off.
Here are the diagrams, parts list, and sales of the parts. Specific to Gaggenau VG353. Additional site to order parts: Essentials For Your Home website, just put in the part number from the diagram.
You have 2 line, 2 load, and if there is an indicator light, 1 for that and 1 ground. The other guy may be right about the 2 grounds, if not, the indicator light may have a connection for hooking it to another light in series. The tech cannot understand the schematic? get someone who can.
Sounds like the spill got into one of the burner switches. This is not a big problem. Once it drys out it should return to normal. However if it keeps on clicking it could mean that one of the switches shorted out and will need to be replaced. The switches are located under the burner control knobs on the valve. Hope this helps. Catriver
