1992 Honda Accord Logo
Posted on Nov 06, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i replace the heater blower motor - 1992 Honda Accord
Anonymous
Level 2:
  • Expert 155 Answers
  • Posted on Nov 06, 2009
Anonymous
Expert
Level 2:
Answers
155
Questions
0
Helped
95156
Points
602
Remove the glove box.Then remove the glove box lower frame.The blower motor will be on the
right hand side under the dash.Remove three 10 mm screws.After removing the screws pull the
blower motor forward and up.There will be three harnesses connected in the lower right side
of the blower.
Where is the blower motor located
      The heater blower motor resistor is located underneath the dashboard in the heater/AC compartment.
      Heater Blower Motor Resistor Replacement - YourMechanic
      https://www.yourmechanic.com/.../heater-blower-motor-resistor-replaceme...
    Feedback
    Replacing A Blower Motor That Doesn't Blow - YouTube
    ? 2:29
    https://www.youtube.com/watch?v=4edK8fa-Ypg
    Mar 9, 2011 - Uploaded by Scotty Kilmer
    Scotty Kilmer, mechanic for the last 46 years, shows how you can replace a broken blower motor in your car ...
    Blower Motor Replacement and More - YouTube
    ? 13:19
    https://www.youtube.com/watch?v=2p5QYd58sTk
    Jun 12, 2012 - Uploaded by talyn875
    Do not try this at home. For HVAC professional use only. This video shows yours truly changing a blower motor ...
How to remove and install heater blower motor
    images for How to remove and install heater blower motor
    More images for How to remove and install heater blower motor
    How To Install Replace Heater AC Blower Motor Chevy ...
    ? 7:26
    https://www.youtube.com/watch?v=jrGFY6yqvFM
    Jan 4, 2011 - Uploaded by 1A Auto Parts
    How To Install Replace Heater AC Blower Motor Chevy Silverado ..... you remove the cover, there is what looks like a door next to the motor that ...
1helpful
My heater blowers dnt work and i need to knw where i can locate the resister blocks for my heater blowers so i can ghange them
Its located under dash,or near glove box.
The dash panel lower side has to be out.
HEATER BLOWER MOTOR
Its faulty blower motor resistor. The low and medium speed on blower motor is controlled by resistor and its actual speed is high. So because resistor is not working, blower motors actual speed which is high is working.
It can be faulty blower motor or faulty blower motor resistor. Get the blower motor inspected. If it's faulty it has to be replaced.
For blower motor testing and replacing, check the link below: ----
Blower motor Testing/replacing for all vehicles?
http://repairhelpcenter.blogspot.in/2012/02/blower-motor-replacing-for-all-vehicles.html
These will help.
Thanks.
Heater is not working
HEATER BLOWER MOTOR
These will help.
Thanks.
The motor for the heater is not working
HEATER BLOWER MOTOR
It can be faulty blower motor or faulty blower motor resistor. Get the blower motor inspected.If its faulty it has to be replaced.
For blower motor testing and replacing,check the link below:----
These will help.
Thanks.
Heater blower don't work
It can be faulty blower motor or faulty blower motor resistor.Get the blower motor inspected.If its faulty it has to be replaced.
Blower motor Testing/replacing for all vehicles? http://repairhelpcenter.blogspot.in/2012/02/blower-motor-replacing-for-all-vehicles.html
These will help.
Thanks.
2helpful
1992 323 mazda want blow heat out
REPLACE THERMOSTAT.IF ALREADY DONE.CHECK HEATER BLOWER MOTOR SEE IF POWER GOING TO HEATER BLOWER MOTOR.IF YES BLOWER MOTOR BAD.IF NO POWER GOING TO BLOWER MOTOR CHECK AC AND HEATER CONTROL FUSE AND CHECK BLOWER MOTOR FUSE AND RELAY IF ALL IS GOOD CHECK SEE IF POWER GOING TO AC AND HEATER CONTROL SWITCH IF YES THE AC AND HEATER CONTROL SWITCH COULD BE BAD.
2helpful
How to replace a blower motor in a 1996 ford thunderbird lx
Removal
  1. Remove the glove compartment liner to gain access to the heater blower motor and blower motor wheel assembly mounting screws.
  1. Use a small screwdriver to remove clip retaining hydraulic damper strut.
  1. Remove four screws and remove the heater blower motor assembly and blower motor wheel assembly from the heater blower motor housing.
Installation
  1. Using a new seal, position the heater blower motor and blower motor wheel assembly to the heater blower motor housing with the flat side of the flange near the heater blower motor switch resistor (18591). Install the four retaining screws.
  1. Tape the heater blower motor power lead to the air inlet duct to keep the wire away from the blower outlet during installation.
  1. Install the heater blower motor and blower motor wheel assembly in the vehicle.
  1. Install the glove compartment liner.
1helpful
3answers
Everytime i turn my heater on heater on works and blows fuse?
fuse blows. unplug heater blower motor turn ignition on, turn heater on, does fuse blow? if not need to replace heater blower motor
Blower motor went aol.
replace blower motor!! heater core and blower motor are 2 different things in the heater system
Top Honda Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Honda Expert? Answer questions, earn points and help others
