The microwave will not microwave anything. Also the ventilation fan comes on and stays on. I have to unplug the unit to turn the fan off. The only buttons that work are the fan speed buttons. This is a GE profile Spacemaker XL1800. Thanks
If the fan in your Amana 10D microwave stays on and doesn't shut off until the unit is unplugged and re-plugged, there could be an issue with the fan motor or the control board. Here are some things to try:
1. Check to make sure the vent is clear and unobstructed. If the vent is blocked, it can cause the fan to stay on.
2. Check the fan motor. The fan motor is responsible for turning the fan on and off. If it is faulty, it can cause the fan to stay on continuously.
3. Check the control board. The control board is responsible for controlling the functions of the microwave, including the fan. If it is faulty, it can cause the fan to stay on or not function properly.
If none of these solutions fix the issue, it is possible that there is a problem with the microwave itself. In this case, it is recommended to contact a professional appliance repair service for further assistance.
This is normal. Kenmore microwaves will stay running with fan and light on for a short time after food is cooked. The reason is to air out the microwave after cooking. Things like pop corn, Bacon etc. have strong smells after cooking. The ventilation helps to remove odors.
Many microwaves have similar issues. Usually, (not always) only the light is on and the fan is running, not the section that produces the microwaves. This problem can be caused by the door switches that are out of alignment or a defective control board.
There are two things that come to mind, the magnetron is starting to fail, or the strapping has come loose on the fan motor housing, unplug microwave oven and remove top, [several screws] carefully inspect the fan for any loose mounts and tighten.
Had the same issue, leave Microwave unplugged for 30 minutes and then plug back in. My fax stopped blowing and now fucntions 100% normal again HI/LO / OFF
To allow us to help you effectively (at no charge), please post a NEW problem to FixYa, and please
include your brand name and the full model number from the tag in or on
the unit, your symptoms ("my maytag microwaves fan stays on, i broke the bottom latch and glued it back on, still stays on'"), as well as the answers to these questions:
Which fan is it, the internal
cooling fan, which comes on automatically whenever the unit is
microwaving?
Or the hood vent exhaust fan which you can turn on and off
manually?
Oh, it turns out the the microwave was over heated and the fan was cooling it. The fan will automatically turn on and stay on until your microwave reaches normal temp. just unplug your microwave and let it cool off. then plug it in and everything should be just fine.
