I,ve Uniden cordless phone which i got 2 years back..Now the base is not working...Can i use the phone with base of other models of the same company.Can you help me out..
Here are a few options; 1) your picture shows two bases, if that is the case, is it happening to both bases/phones, if not check terminals to make sure both are clean and connecting well. 2) if possibly exchange them, Uniden's are usually good phones, I've owned them before. 3) If you have one phone holding a charge and the other not, exchange the batteries and see if it's specific to the battery set. If so, you can purchase replacements at several stores. Hope that helps.
When someone calls you and your phone behaves this way, does the caller get disconnected? The phone may be causing this, but it may also be due to trouble in the telephone line itself. The trouble is caused by defective wiring, a partial short circuit. When you pick up your phone to call out, the voltage on the phone line is low and it works normally. When you get an incoming call, a high voltage is sent to ring the phone. Because of the partial short, the phone company's equipment thinks you've answered the call as soon as the ringing starts. But you haven't picked up the phone, so the phone company's equipment thinks you've hung up and disconnects the call. The result is that short burst of ringing.
Disconnect the cordless phone base unit from the line and try another phone. If you still have the trouble this confirms the line is at fault. You'll need to contact your phone service provider for service. If it's in the outside wiring, they're responsible for repair. If the problem is in your home wiring, you may need to pay them unless you have a wiring maintenance plan.
If the problem goes away when the cordless base is disconnected, then it's time for a new phone.
Often the handsets must be re-registered when they won't work. Sometimes they have to be de-registered, then re-registered before getting them to work. Uniden has many different model number 5.8 GHz cordless phones, send a comment with the model number and I will give specific help on your cordless. I have included a link where Uniden cordless manuals can be downloaded if you need it.
You might need to re-register the remote handset with the base. Normally this is just a matter of putting the handset onto the base unit, but check your owner's guide for the details of your model.
the base was destroyed in fire, only the phone left. I bought a similar model cordless phone, but cannot add the former phone to the new cordless phone as without the base of the former phone I can reset the former phone. Can i reset the former phone without the base?
I always tell people NOT to buy new batteries to try and fix their cordless phone. It seems to rarely solve the problem and you are usually better off just spending the money on a new phone.
Unfortunately 5 years is a long time for cordless phones these days.
There are so many brands, and so many thousands of models, it's impossible to keep track of them all.
