Question about HP LaserJet P2055d Printer
When printing pdf, i get an error "error printing". I am using adobe acrobat 9.2 on windows vista
Posted by buto12003 on
Azum Saeed
  • 400 Answers
Sir,
You are suggested to make sure if your computer is Reading your printer It is mainly when the drivers are not working properly or there is something wrong with the datacable. Which does not allow the printer to temoprarely store data and cause such error. you can reinstall the drivers and make sure if this not the problem and later change your data cable if not working fine.
Posted on Nov 06, 2009
I'm getting this message every few minutes on a Vista system. Acrord32.exe-No Disk "there is no disk in the drive\Device\Harddisk4\DR4.
These instructions apply If you have "Adobe Acrobat Reader" installed, not if you have the paid for, full suite "Adobe Acrobat".
1. Completely uninstal "Adobe Acrobat Reader"
more details (troubleshooting):
https://forums.adobe.com/thread/755658
2. Reinstall (if you so choose) "Adobe Acrobat Reader"
http://get.adobe.com/reader/
or use an alternative (less bloated) PDF-reader:
http://www.tracker-software.com/product/pdf-xchange-viewer
Feb 14, 2015 | Microsoft Windows Vista Business Edition...
What is acrobat reader?
Adobe Acrobat is a family of computer programs developed by Adobe Systems, designed to view, create, manipulate and manage files in Adobe's
Plug-in from Adobe. It reads documents in PDF format on any platform.
A program from Adobe that lets you capture a document and then view it in its original format and appearance
Adobe has changed the names of the products in the Acrobat family regularly, also splitting-up, joining, or discontinuing products. Between version 3 and 5, Standard and Professional versions were one product simply called Adobe Acrobat.
As of October 2009[update], the current main members of the Adobe Acrobat family are:
64px-adobe_reader.svg.png magnify-clip.pngAdobe Reader 8/9 Icon
  • Adobe Reader 9 (Windows, Mac and Unix)
  • Adobe Acrobat 9 (Windows & Mac only; no Unix version)
    • Adobe Acrobat 9 Standard
    • Adobe Acrobat 9 Pro
    • Adobe Acrobat 9 Pro Extended (includes Adobe Presenter)
The latest version
Version 9.0 Adobe Acrobat 9.0 was released July 2008:[10][11]
  • PDF version 1.7 (and prior) supported. There are Adobe extensions to PDF 1.7 for Acrobat 9.
  • Product Family includes: Acrobat Standard 9 (Windows only), Acrobat Pro 9, Acrobat Pro Extended 9 (Windows only).
  • Pro Extended Version includes Adobe Presenter and the features of Acrobat 3D.
  • The ability to create Acroforms was restored to Acrobat Standard in this release (in versions 6 through 8, Acrobat Professional was required).
  • Enable real-time collaboration of PDFs with synchronized document views and chat.
  • Improved Web Capture for capturing entire web pages or just some parts into PDF.
  • Integration with acrobat.com to enable storage and sharing of PDF files.
  • Personalize a PDF Portfolio with customizable templates for navigation and branding.
  • Compare and highlight the differences between two versions of a PDF document.
  • Insert FLV (Flash) or H.264 video for direct playback in Adobe Acrobat and Adobe Reader.
  • Convert a variety of video formats to FLV for playback in PDF.
  • Create PDF maps by importing geospatial files that retain metadata and coordinates.
  • OCR PDFs (Paper Capture) using ClearScan. Adobe ClearScan technology creates custom Type1-CID fonts to match the visual appearance of a scanned document after optical character recognition (OCR). ClearScan does not replace the fonts with your system fonts or substitute them by Type1-MM (as in Acrobat 8 and earlier versions), but uses these newly created custom fonts. The custom fonts are embedded in the PDF file (this is obviously mandatory). If the OCR does not recognize a word with enough confidence, then the image (bitmap) of the word is shown in the PDF and the text is put above but hidden (same as what is made in "Searchable Image" mode).
  • Adobe Reader 9 drops support for Adobe Reader Extensions 5 and 6 which permit Adobe Reader client software to save changes to filled-in forms in PDFs. Adobe Reader Extensions 6.1 and newer are still supported. Legacy PDFs will still be viewable, however they will open with the warning "This document enables Reader capabilities that are no longer enabled in this Reader version."[12]
  • On March 10, 2009, Adobe Reader 9.1 was released which addresses a number of customer workflow issues and a critical security vulnerability while providing more stability.[13]
  • On May 12, 2009, Adobe Reader 9.1.1 was released which addresses two critical security vulnerabilities.[14]
  • On June 9, 2009, update version 9.1.2 was released which addresses a number of critical security vulnerabilities.[15]
  • On July 31, 2009, update version 9.1.3 was released which addresses a number of critical security vulnerabilities.[16]
  • On October 14, 2009, Adobe Acrobat 9.2 was released (added support for Windows 7 x86/x64 and fixed many security issues).[17]
  • On January 12, 2010, Adobe Reader 9.3 was released which addresses a number of critical security vulnerabilities.[18]
  • On February 16, 2010, Adobe Acrobat 9.3.1 was released which addresses two critical security vulnerabilities.[19]
  • On April 13, 2010, Adobe Acrobat 9.3.2 was released which addresses several critical security vulnerabilities.[20]
Jun 03, 2010 | Adobe Computers & Internet
I have downloaded Adobe Acrobat reader 9, I have made adobe acrobat reader the associated default programme for pdf files and still I am unable to print a pdf file from the internet or e-mail without...
when you send a job to your printer from the internet it is basically the same as downloading the program first before it can be spooled. this is causing a time out problem with your printer.
Dec 28, 2009 | Adobe Acrobat Reader 3.0 for PC/Unix/Mac
I am using Adobe Acrobat version 9, Windows Vista
Hi Jerry! Adobe Acrobat is indeed a excellent PDF editing program. However, you are having trouble on it, why don't you use another software. You can try LightPDF. This program is much easier to use and comes with several useful features such as OCR function and converter. Try it here: https://lightpdf.com/
Dec 11, 2009 | Adobe Computers & Internet
Want an owner's guide too many dead ends
www.windowsvistauserguide.com
or
  1. [PDF] Introducing Microsoft Windows Vista File Format: PDF/Adobe Acrobat
    Understanding Windows Vista User Accounts and Windows Security. Permissions . ...... Windows Vista has two primary types of local user accounts: ...
    download.microsoft.com/.../5/.../Introducing_Windows_Vista.pdf - Similar -
    by WR Stanek - 2006 - Cited by 1 - Related articles
  2. [PDF] Windows Vista File Format: PDF/Adobe Acrobat
    Windows Vista – Power users guide. Page 1 of 66. Written by Mike Halsey, ...... this guide, this comes as a warning to us all! User Account Control (UAC) ...
    www.inspirare.net/pdf/VistaPower.pdf - Similar -
Jun 27, 2009 | Microsoft Windows Vista Ultimate Edition
HP C6180 will not print a PDF document, causes paper jam.
The problem is an incompatibility between Adobe Acrobat and HP Photosoft software... the solution is to stop using Adobe Acrobat software as your primary PDF reader... to see why and what is the alternative continue reading...
I had several Windows XP laptop/netbook/desktops running on my home wireless network perfectly. Then I had to replace the desktop with Windows Vista, and that's where the problems started. Despite updating the HP driver software, the Photosmart printer would not work with the Vista machine unless it was physically connected through the USB port. But this solution created a new problem with the wireless XP machines, they would now cause a print jam every time I printed a PDF. I had Acrobat Reader on one machine and Acrobat Pro on the other. Any other file format would print fine... I could print a PDF from within Adobe Photoshop... and re-installing the old HP driver software eliminated the problem (but then the Vista machine wouldn't print anything)... thus the problem had to be Acrobat.
With the newest updated HP software in place I uninstalled Acrobat Reader and installed a freeware readers. THE PROBLEM WAS SOLVED. I tested three and all printed PDFs to the HP Photosmart printer with no problem. I tried Adobe Acrobat again, and it jammed. These freeware PDF readers are all small and fast compared to Acrobat which is big, bloated, and slow.
My suggestion is to use Foxit, which is the easiest and fastest, and seemes to work as a plugin with all the browsers (IE, Firefox, Chrome). You can get it from trusted sites like CNET ( http://download.cnet.com/Foxit-Reader/3000-10743_4-10313206.html ) or from the company ( http://www.foxitsoftware.com/pdf/reader/ ).
BTW, I do maintain Acrobat Pro on one machine because of the advanced features I use, but I configured it to not be the default PDF reader and print through Foxit on my home network.
By the way, ANYONE WHO SUGGESTS CONTACTING HP SUPPORT ABOUT PRINTERS THIS OLD IS BEING LAZY OR NOT PAYING ATTENTION... HP WON'T HELP UNLESS YOU PAY FOR THE INCIDENT, AND THEN THEY TELL YOU TO DO THE OBVIOUS (i.e., install new drivers) WHICH DOESN'T WORK, WHEREUPON THEY WILL SAY IT'S NOT AN HP PROBLEM BUT THE "OTHER GUYS" PROBLEM. Many people have played this game with HP before so don't waste your time and money expecting a different result.
Apr 27, 2009 | HP Photosmart C6180 All-In-One InkJet...
Is there any way to open an Acrobat 9 file with Adobe Reader 5?
Download the Adobe Reader 9 software. It's free from Adobe.
Mar 01, 2009 | Adobe Acrobat 6.0 for PC
I am using vista and have adobe acrobat, when i click on an online link to a pdf file it says 'acrobat not found' i have added the program to the list of accepted programs in the firewall but still no joy.
try downloading adobe reader 9 or 8 and install it over you existing adobe reader, adobe acrobat is an old bit of software which is obsolete now
Nov 15, 2008 | Computers & Internet
Adobe acrobat reader 7 has problem with window vista need upgrade or patch to fix problem
acrobat 7 is not compatible with Vista, you need to upgrade to acrobat reader 9, it's free from here
Sep 01, 2008 | Computers & Internet
HP LaserJet P2055d Printer Logo
158 people viewed this question
Ekse
efs_perpends
efs_perpends
