Question about Nokia 6300 Cellular Phone
My nokia 6300 phone will not turn on. when i put the charger in it lights the two side lights on and the battery shows its charging but it will still not turn on. is there another way of turning the phone on without using the 'power' button?
Posted by michael_may5 on
Shehu Pro
  • 1,284 Answers
That means power on button is bad and you need to take it to a technician to fix it for you.
GOODLUCK
Posted on Jan 07, 2010
Nokia 6300 showing charging but not increasing battery charge level
Could be possible that the charger or the battery by itself is faulty as many of them gets reverse polarity in the cell. It will be ideal to swap and check with the same type from a friend which is most easy as many are around so as to confirm before you can invest.
Please clean the battery contacts and the terminals.
Apr 05, 2011 | Nokia 6300 Cellular Phone
I am using Nokia 6300 model, when i am putting charger it showing as charging, but not charging, when i am replacing the same battery with other mobile then its charging, by that i came to know that there...
Hi! There some is a problem with the charger connection port, so you could always replace that. I had the same problem i got the phone charger port replaced, this saved me money on not getting any chargers.
Hope this helps Fazal Enterprise - www.fazalenterprise.co.uk
Mar 03, 2011 | Nokia 6300 Cellular Phone
Nokia 6300 charging not supported
When your phone shows charging not supported. First, you need to try a another battery on the phone, if it says the same thing, then try to use another charger, and if it shows the same thing, then you need to fix the charging port of the phone.
Before you do that, test, your battery and charger on another phone to see what happens, if they both work fine, then you need to fix the charging port of the phone.
Take care and good luck
Oct 13, 2010 | Nokia 6300 Cellular Phone
Bad contact charger
The charging port is bad, so you have to take it to a technician or get a universal or desktop charger to charge you battery.
Nov 03, 2009 | Cell Phones
Charging problem with the nokia6300. stop charging and says charger not compatible
either your baterry or charger must is not working or their must be problem with the charger port........you need to go to noia care.......as there is no software problem......
Oct 27, 2009 | Nokia 6300 Cellular Phone
My nokia 6300 is not turning on to charge
hi
check the following :
1/battery nozzls try to sctrach it
2/test the charger with any other supportable nokia
if problem still occurs
that means new charger diode need
dont forget (the rating plz
Dec 01, 2008 | Nokia 6300 Cellular Phone
6300 Won't turn on
my nokia 6300 could not open when i switched on it, its side light on but the display is blank
Feb 26, 2008 | Nokia 6300 Cellular Phone
Nokia 6300 wont power on
check on that battery connector isnt damaged it looks like you middle pad BSI line its not connected properly
Feb 18, 2008 | Nokia 6300 Cellular Phone
Nokia 6300
Keep it on charge for whole night. Or else change the battery
Sep 03, 2007 | Nokia 6300 Cellular Phone
Nokia 6300 Cellular Phone Logo
402 people viewed this question
Top Nokia Cell Phones Experts
Muntejaya Ginting
Muntejaya Ginting
Zaid Anarwala
Zaid Anarwala
SANTHOSH
