Question about Xerox Phaser 8400 Laser Printer
My printer says it's off line and won't print. I'm not sure what setting got changed or how to change it back. how can I change it so it prints again? help please!
Posted by wjkland on
  • Anonymous May 11, 2010
    Is this a "local" printer (connected by cable to a computer) or a "network" printer?
Aleks Fixya
    New Friend:
If it is a network printer try this from CyberPerm
Turn off the SNMP option in the TCP/IP printer port Properties
Right-click the printer, select properties
Select port tab, highlight port, click Configure Port
UnCheck SNMP status Enabled.
Posted on Feb 07, 2013
  • mtgreset Jun 11, 2013
    yes it worked great , thank you
Mohamed Omran
  • 2,567 Answers
1. Open Start menu.
2. Click on "Printers and Faxes"
3. Double-click the icon for your printer.
4. On the menu bar, click "Printer" to open the printer menu. Click on "Use Printer Offline" to remove the check mark. This will bring your printer back online.
If this did not help, check the printer itself & make sure it is not set to be offline.
Posted on Nov 06, 2009
5 Related Answers
Anonymous
  • 2120 Answers
SOURCE: How change default print quality setting?
In printer properties.
Posted on Jan 31, 2009
Anonymous
  • 90 Answers
SOURCE: Communication problem with printer over Airport, i.e. won't print
try uninstalling & reinstaling the printer will only work...
Posted on Apr 25, 2009
Paul Hutchinson
  • 909 Answers
SOURCE: hp officejet, pro k5400 printer,when printing i
That is ink or dirt on the rollers, you need to clean them by lifting the lid, as if you were putting new ink in, and wipeing the rollers that the paper runs through.
Posted on Jun 09, 2009
Anonymous
  • 220 Answers
SOURCE: My printer again skips lines when I print. Also
try replacing the other cartridges, I had the same problem except the printer auto printed red, the problem was that it only allowed me to print some colors because the other ones were empty.
Cheers
Posted on Jun 30, 2009
dick davis
  • 610 Answers
SOURCE: My MFC290C printer will not print in black. I
You need to call Brother at 1-877-brother and tell them your mfc is "missing black". They will tell you where to take it to get the print head replaced under Brothers' warranty. This is a VERY common problem and Brother will cover the cost to repair it.
Posted on Aug 10, 2011
When I print 1 copy from my laptop, it will not stop printing many copies and I tried to copy a photo and there are horizontal lines on the copy. Jacques
The numbers of copies your laptop print out is set in your printer software.
You did probably forget to change the numbers to 1 (one copy).
If you use normal print paper for photos, it will almost always make horizontal lines.
Use photo print paper instead, then it won't happen.
It could also be that your print cartridges need a nozzle cleaning.
Normally your printer software has a mode to this.
Hope this will help you
Regards
Hi , I have a problem with zebra 105sl printer , everytime i print somthing i have to make changes to the settings , eg. make it darker .When i save the settings permenent next time i go tto print i have...
The settings in the printer driver are overriding the saved printer settings.
Do this:
1. Correct the printer settings and save them permanently.
2. Print saved configuration for future reference and to see if it changes.(Power on while holding cancel)
3. Print a label from computer.
4. Print configuration again (Power on while holding cancel).
5. Compare the 1st and 2nd printouts. If they are different then the printer driver is changing the printer settings. In other words the printer settings and the driver are different and the driver settings will override the printer settings before printing.
6. Change the driver settings and this won't happen. Increase the darkness setting in the driver.
HP Deskjet 6980 won't print. Says offline but i don't see how to turn it back online. was working. now not.
Printers often go off line for no reason. It can be genuinely off line or the pc is just not seeing the printer anymore To put it back on line all you need to do is open the print queue (double click on the printers icon in printers devices/ printer and faxes) go to File and in the drop down list it will say "Use printer Offline or Use printer online. click on it and if the pc is seeing the printer if will change and the printer will then start up and print. If this does not work then check your cable to the printer or your network connection to reestablish the connection.
Keeps printing copies of what i copied last week and won't copy what i want this week
((make sure you have the printer turned off)) otherwise you it might print another page if you have multiple prints in the queue you will have to open a file that you are about to print click ok a page will open with a display print queue tab you can see all prints right click on the ones you don't need select cancel
it will be in the print queue where you can stop it printing right click to delete what you are printing you might have to uninstall the printer then reinstall to adjust your print settings
or just go into your printers settings to alter/change the settings
hope this helps
I want to print onto christmas cards, how can I set up my HP photosmart 2610 to do this
To apply the change to all future print jobs or just to the current print job.
To change the print settings for all future jobs
1. In the HP Solution Center, click Settings, point to Print Settings, and then click
Printer Settings.
2. Make changes to the print settings, and click OK.
To change the print settings for the current job
1. On the File menu in your software application, click Print.
2. Make sure the HP All-in-One is the selected printer.
3. Click the button that opens the Properties dialog box.
Depending on your software application, this button might be called Properties,
Options, Printer Setup, Printer, or Preferences.
4. Make changes to the print settings, and click OK.
5. Click Print or OK in the Print dialog box to print the job.
When printed document is sent to printer, it prints with dark lines below each line of print often obscuring every other line of print .
  1. When connected by a USB cable, reseat both ends of the cable going from the computer to the printer.
  2. When connected to a wired or wireless network, make sure the network is working correctly and that the printer is connected to the network.
  3. (to make sure the printer is on the network, print a network set up page, for more information on how refer to the user's guide, refer to the Downloading and Viewing Printer Manuals section for information on how to download and view the user's guide).
  4. Restart the computer.
  5. Turn the printer off.
  6. Unplug the printer power cord from the A/C outlet or surge protector and wait at least 30 seconds.
  7. Plug the printer power cord back into the A/C outlet or surge protector.
  8. Turn the printer back on.
  9. Make sure the desired printer is set as the default printer.
    • For instructions on how to check which printer is set as the default and change it if needed, Click Hereextlink.gif
  10. Print a test page.
    • For instructions on how to print a test page from Windows, Click Hereextlink.gif
  11. Run the automated printer fix available from Microsoft.
    • For instructions on how to run the automated printer fix available from Microsoft,
      Click Here
  12. Uninstall the printer driver, download and install the latest printer driver.
How do I change the toner density on the push button display when it is locked with an * We have low or a feint print out of the fine print on the print settings print out test sheets. I have cleaned all...
A new laser could help, but you should make sure the toner save is turned off, it makes toner last longer by making light prints. Toner save is set in printer properties in the control panel
My printer makes lines through all the pictures i try to print
Make sure your quality options is set for best photo, also change paper to glossy photo paper. Under the maintenance button try to clean the print head and then try a print head alignment. I hope this helps you........Hutch
Language
Enter the menu,
Change Language set to American. It is under symbol sets. Also change code page to usa.
Menu Mode
1. Verify that paper and the ribbon are installed.
2. Power ON the printer.
3. Press SELECT and place the printer OFF-LINE (SELECT will not be lit).
4. Press QUIET to enter Menu Mode.
5. The line shown below will print.
Printer Control Emulation Mode Epson LQ 6. Go to Step A to print the current menu.
Go to Step B to change the menu.
Step A
Press PRINT to print the current Menu.
Press EXIT to exit Menu Mode.
The printer will go ON-LINE. (SELECT will light.)
Step B
Press GROUP to move through the groups of the Menu.
A line prints, showing the Group.
Press ITEM to move through the items in a group.
A line prints, showing the Item.
Press SET to change the setting for an item.
A line prints, showing the Setting.
Problem with oki microline 395
Enter the menu,
Menu Mode
2. Power ON the printer4.gif.
5. The line shown below will print4.gif.
Step A
Step B
A line prints4.gif, showing the Group.
Xerox Phaser 8400 Laser Printer Logo
Top Xerox Office Equipment & Supplies Experts
Ekse
Mehandi Husain ...
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
