Question about HP LaserJet 2840 Printer
Hp laserjet 2840 - need to reset language to english from a foreign language I do not understand
Posted by jmorrison725 on
Ghaffar
    New Friend:
How to change the hp laserjet2840
Posted on Dec 12, 2012
Seeker5211
    Genius:
  • 1,089 Answers
Under device settings Go to system settings, Then go to system setup. You can change the language from there.
Posted on May 17, 2010
How do I reset the language to english on an M401n hp printer
1. Turn the product off.
2. Perform one of the following steps:
- LCD control panel models: Simultaneously press and hold the right arrow button and the Cancel button. Keep these buttons depressed as you turn the product on.
- Touchscreen control panel models: Press and hold the lower right quadrant of the touchscreen. Keep the quadrant depressed as you turn the product on.
3. When the Permanent Storage Init. message appears on the display, release the buttons.
4. When the product has finished the NVRAM initialization, it returns to the Ready state.
Feb 10, 2015 | HP LaserJet Pro 400 M401N Laser Printer
How to reset the language in nikon s3100
Assuming the the s3100 is like other Nikon compact cameras, go into the Menus and look for Set-up. "Language" will be one of the choices. Unfortunately, everything will be in the foreign language the camera is currently set to until you make the change. If the language is a common one, you may be able to find someone to help you. If not, I would contact the foreign language department of a local university for assistance.
Jul 09, 2014 | Nikon Coolpix S3100 Silver Hd Digital...
Hp laser Jet 2840 jammed carousel how to realign the gears?
You need a tech manual for the process. I would try Feedroller.com for the techmanual. It is rather involved.
Mar 17, 2013 | HP LaserJet 2550L Printer
Hi, I have aproblem with the HP Laser Jet 2840 all in one.. display shows Scanner error 3. i tried several times switching off and on but it does not help. However, each time i switch it on, the scanner...
You are going to have to have it looked at by a trained printer tech.
Just from your description, it sounds like the scanner/copier assembly needs replacing.
Aug 03, 2011 | HP LaserJet 2840 All-In-One Printer
Hi, we have a problem with laserjet m1005 mfp where by mistake the language has been changed and i cannot even come to the menu button of "factory setting" to change it to "english...
JUST TRY TO RE-CALL WHERE WAS THE FACTORY SETTINGS OPTION LOCATED PRESS IT ENGLISH LANGUAGE OPTION WILL APPEAR YOU CAN SELECT IT FROM THERE
IF NOT TRY RESETTING THE PRINTER BY REMOVING THE CARTRIGE AND INSTALLING IT AGAIN
Dec 06, 2010 | HP LaserJet M1005 Printer
HELP trying to change back to english
Just un install and reinstall.
If problem then keep me posting!
Jun 09, 2009 | HP LaserJet 3015 All-In-One Printer
Language
It worked with the 2600n Color LaserJet by having the printer on first (shows the foreign language), then hold down the green button and turn it off and then on again while still holding the button.
Doing this will back to English
Oct 31, 2008 | HP Color LaserJet 2600n Printer
Language change
Press the check button and the right arrow button in this combination:
check, arrow, check, check, check.
This should bring you back to the ready screen after a brief pause.
Jul 17, 2008 | HP Color LaserJet 2600n Printer
HP LaserJet 2840 Printer Logo
278 people viewed this question
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
