Question about Haier HVZ040ABH5S Stainless Steel Wine Cooler
Light stays on. It was flashing LL for the lower
Dual zone Haier wine cooler. The light stays on signaling a problem. It was flashing LL for the lower compartment. Now that has stopped but the temp remains at 32 or 33 even though it is set to 55. There was some ice build up inside the fridge that I have cleaned out. Could it be something with the coil or is the thermostat bad?
Anonymous
    New Friend:
  • 5 Answers
The first step is shutting it off for 24 hours with the door open to make sure there is not any ice on the evaporator. next, make sure the door seal is sealing properly. if neither of those are the culprit, you may need a new thermostat.
Posted on Nov 06, 2009
Testimonial: "Thanks. I am thinking more and more that it is the thermostat because it keeps going up and down only for the lower zone. Upper zone is okay."
The led light for the upper level flashes LL and there is bipbip sound all the time.
Mine is doing the same thing I believe. My solution is to jam the offending push button so that it is always depressed. Be sure that it is at the required temperature when you push it in for the final time. I used the end of a flat toothpick to wedge in the gap beside the button.
Dec 11, 2015 | Koolatron 18 Bottle Dual Zone Wine Cooler
Why would I need a dual zone wine cooler?
The dual zone wine cooler style is ideal for keeping both reds and white wine without having to restore them in two different wine coolers.
Aug 14, 2012 | Furniture
Where can I find a wine cooler that has 2 or more different temperatures zones?
there is a wide variety of dual zone wine cooler and theirprices range from around $300 up to $3000 and even more, depends on their and manufacturer. I recommend taking a slightly bigger wine cooler thanintended since once you have your wine cooler you start getting more and morewines and you'll end up with no room...just google dual zone wine coolers
May 29, 2012 | Furniture
The temp is 25 and is stuck on LL
replace the temp sensor first
$4.76 from Haier part# RF-6250-01
still stays at 25 degrees?
replace the control board & you should be done.
$26.81 from Haier part# RF-0668-04
Oct 23, 2011 | Haier BC112G Wine Cooler
Wine temp on Haier wine cooler BC112G went to LL, opened up and some champagnes frozen, other wines very cold, condensation all over door, how do you fix this error?
The error is likely caused by a bad temperature sensor. The control board may still be Okay.
Replacing both of them is recommended.
Check this link for parts: http://www.partstore.com/Model/HAIER+AMERICA+TRADING/Haier/BC112G.aspx
Dec 31, 2010 | Haier BC112G Wine Cooler
Are red wines stored on the top or bottom of the Haier BC112G wine cooler? How about white wine? Have lost my owners manual and don't know where to put red wine when the temp is set cooler for white wine
http://www.haieramerica.com/en/asset/archived/BC112G.pdf
is the link to your manual.Typically in a dual temperature zone wine cooler whites are stored in the bottom and reds on top as whites are better a little colder and the cold air will drop to the bottom of the unit.
Hope this helps!
Jun 14, 2010 | Haier BC112G Wine Cooler
Wine cooler
cheak the machine main on/off switch, cheak the in$out phase line
Jun 21, 2008 | Haier HVT12ABS Compact Wine Cooler
Lost manual for wine fidge
Push the red and white buttons at the same time for about 3 seconds-the temp will start to flash-then press the white button to lower the set temp-when you have it where you want it then push the set buttom
Oct 18, 2007 | Haier HVF060A Wine Cooler
Haier HVZ040ABH5S Stainless Steel Wine Cooler Logo
230 people viewed this question
Top Haier Refrigerators Experts
Vernon Taylor
John Tripp
John Tripp
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
