Question about Philips Magnavox 42MF521D/37 Television
My plasma screen goes black on bottom 1/2 of the screen
My Magnavox 42" plasma, the bottom half of the TV screen goes black off and on, the warmer it gets, the more frequent and longer duration of the black screen. Any ideas?
Posted by kschnipp2000 on
Anonymous
    President:
  • 1,284 Answers
In most cases the lower Y-Buffer board causes this issue. Unless you know how to work on a TV it is suggested that you have a technician look at the TV and repair it for you.
Posted on Nov 05, 2009
5 Related Answers
Anonymous
SOURCE: my 42" plasma tv screen went black but there is still audo
I have dell w4201chd and the screen went blank no pitcure or sound,I have power to the lcd lights on motherborad can you help me?
Posted on Aug 09, 2010
Anonymous
  • 90 Answers
SOURCE: black on bottom of screen
do me a fovor, i need your firmware version? to do this, press Input 619. in the center of the bottom of the screen, is three digits 5?.? please provide me with these numbers. you may just need firmware updates.
Posted on Jan 30, 2009
Anonymous
SOURCE: LG plasma tv has half black screen
Hi Hi
Posted on Jun 12, 2009
roety
Eric Rotmil
  • 587 Answers
SOURCE: horizontal lines on screen
well if they run all the way up and are on every input through then menu the panel is NG, some panels are around $500 now.
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Posted on Aug 01, 2009
dougmcb
  • 4 Answers
SOURCE: Bottom half of the screen goes black frequently.
You can start here: http://www.support.philips.com/support/catalog/catalog.jsp;jsessionid=87CE21B6A8264B83B8D00501ADACA8BF.app107-drp1?_dyncharset=UTF-8&country=&categoryid=FLAT_TV_CA_US_CARE&userLanguage=en&navCount=1&groupId=TV_GR_US_CARE&catalogType=&navAction=push&userCountry=us&title=Flat+TV+(plasma%2C+LCD)
Enter the exact Model Numbere in the search text field.
First verify the exact Model Number of your TV. Mine is a 42PF7220A/37.
go to:
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=42PF7220A/37&scy=us&slg=en
On this page I found listed under "Software2.gif & drivers" the Firmware Upgrade Software 42PF7220A/37 v1.5.0.0
I downloaded the compressed file and extracted it to a USB Flash Drive2.gif.
After you extract the file you will have 2 files...."autorun.upg" and a "readme.txt".
Make sure the USB Flash Drive2.gif has only one file on it (autorun.upg)
Make sure the TV is turned off.
Put the USB Flash Drive in any of the USB ports on the TV.
Turn the TV power on with the Power Button on the righthand side of the TV.
The TV will display an Update screen.
Let the TV run through all 3 processes.
Turn the TV off and remove the USB Flash Drive.
Power the TV back up.
Hopefully the Updates fixed the problem.....
Posted on Sep 29, 2009
1helpful
2answers
While watching tv half the screen goes black
Download software from the Phillips web site. Use a usb flashdrive to transfer the download to the TV. This worked well for us and our picture is better than ever.
Picture goes black on bottom half of the screen
You have a bad connection to the panel or bad caps on the boards. Not something for the DIY'er. High voltages in plasma sets.
Magnavox plasma tv model 42mf230a/37 sound but ni
Replace lower scan converter PCB, which plugged into Y-Sustainer Board, located to the left of the display if you poke back cover open. There are 2 of them, but in some models might be the one, long PCB.don't wait to fix it! otherwise, you will knock out Y-
Sustainer and upper scan converter. That will cause you to spend few hundreds to fix it.
Good luck,
Alex's TV Service,
Philadelphia,
Pa, 215-806-5980.
2answers
1/2 the screen goes black
vera partner what you have is a problem of poor voltage or damaged card card check your x that is the bottom of the plasma must consist of at least four cards
4helpful
3answers
Black screen
first try the address board or buffer board.if this
does not repair it,the panel is defective.
Bottom half of screen is black
its ur diaplay problem.. go for a change of new display...
5helpful
Model 42mf231d/17 42" plasma
If the loss of picture is either on top half or bottom half of screen. there are y buffer boards that go from top to bottom on left side of screen when looking at back that control those sections. when there is loss of half of picture then buffer associated with that area would be at fault and would need to be replaced. when i see a degrading symptom such as loss of picture on top half or bottom half leading to no picture issue normally you would check heat syncs on y sustain board and if not heating up after a few minutes of being turned on would recommend replacing y main and both y upper and lower y buffer boards as they complete a circuit
2helpful
42" Philips plasma screen goes black
You have a Ysus problem. Sounds like a cold solder joint or loss connections on ysus main board.
Philips Magnavox 42MF521D/37 Television Logo
Top Philips Televison & Video Experts
 Francisco Mauricio...
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
