Question about Mag Innovision LT776s 17" LCD Monitor
Vertical lines and flickering for 2 or 3 minutes
Posted by jgarant on
How to fix LG TV Vertical lines.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Lg55lv4400-va 55" flatscreen tv ( not a plazma) has developed a wide flickering vertical flickering stripe down the screen. Has been fine . Goes away once in a while. An Ideas what is wrong ?
My acer projector flickers after 10 minutes and very hot air comes out from its vents, making it difficult to stand near it and it also show vertical lines.
the projector flickers after 10 minutes ,it seems that the lamp ballast is failing
shows with vertical lines, it seems that the LCD panels are failing or the panels cable not be tightly plugged (panel-cable plugs into the mother board)
We supply original projector lamp,bulb,parts,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry,Lampdeng Limited
Sanyo dp26648 has sound, but has vertical lines w/picture popping in periodically.
change your device cables or try to put at a pc to check if isworking your pc
Vertical lines showing up after being on for awhile
Eh, I can't be too sure, but it sounds like it's either a heat issue, a signal issue, or a backlight issue. Either way, if it's still under warranty I'd send it in.
1helpful
2answers
Plasma "warm up" is now up to 30 minutes and climbing
put a towel across the top of the tv so it can heat up faster and you will get your picture. be carefull!!
Vertical lines in my laptop screen
My understanding is that you have 2 laptops with the same problem, if that is the case, you need to replace the lcd. When you have lines on lcd's, that is a sign of a bad lcd.
1helpful
Parallel vertical lines through left side of Panasonic Plasma tv
This sounds like one of the driver boards at the bottom or top of the screen has an intermittent fault. The set will have to be taken in to a service centre.
3answers
Mag Innovision LT776s 17" LCD Monitor Logo
Top Mag Innovision Computers & Internet Experts
Ekse
Mandeep  Singh
Mandeep Singh
Are you a Mag Innovision Computer and Internet Expert? Answer questions, earn points and help others
