Cameras Logo
Anonymous Posted on Nov 05, 2009
Polaroid i534 When I play back using windows media player or ulead, the sound and the video are out of sync. Also at the end the sound keeps going and the picture has stopped. What's up?
4 Related Answers
hirschjaeger
  • Posted on Jun 10, 2008
SOURCE: Polaroid CAA 03040S Camcorder no sound during playback
The camcorder sound can be set to one of ten levels, with 0 being no sound at all.
Turn the camcorder on and let it boot up. Press the Mode button. Move the cursor to the bottom icon, the "hammer and screwdriver." Press the Menu button to select this icon. Now use the down arrow button to scroll down to "Volume." Now press the menu key to select this, and you can check/set your volume as you wish.
You can download the PDF manual for this and all other current Polaroid cameras at www.polaroid.com
Anonymous
  • 2071 Answers
  • Posted on Sep 06, 2008
SOURCE: player freezes partway through movie
If for some reason you would opt for user performed action, then pls try:
1. reset, unplug from the mains for at least an hour and try again;
2. check if there is a slide switch of some sort at the rear of the unit;
3. check if there may be a pinhole somewhere along the bottom of the loading tray where a blunted point safety pin maybe inserted;
4. open the top cover and manually eject the tray;
5. check internally if there is a mechanical problem such as a slipping/cut belt, gears that do not mesh correctly;
6. if the unit has been in use for some time, it may simply need cleaning and re-application of lubricant in the mechanical assembly.
The slider mechanism, depending on the age of the unit and , consists of the small chrome rail, a drive motor, a small gear assembly, and (in some units) a small belt that drives the slider unit via the motor. This small belt causes all sorts of problems. If the belt is broken or slipping, it can cause skipping, dropouts, or simply no start up at all. Also, if the belt breaks in the middle of the disc, the drive mechanism gets hair or dirt wrapped up into the gears, or the pick-up assembly doesn’t return to the start position (called home), the unit will (99% of the time) refuse to release the disc, causing it to become stuck inside the unit. There’s a little micro or leaf type switch located at home position that sometimes gets dirty or breaks and, causing this problem also.
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE:
Rifaa
Rifaa-ath Razei
  • 99 Answers
  • Posted on Nov 18, 2008
SOURCE: i cant see the dvd when it is playing, no video just sound
did u check the cablle connections
Cheers
Anonymous
  • Posted on Jan 01, 2009
SOURCE: i can not sync from
hahaha ur fuken screwed XD just kidding, myne wont play videos
2helpful
3answers
How do i download music on my mp3 player?
How to Put Songs on Disney Mix Max
The Disney Mix Max portable media player is capable of playing audio files in the MP3 format. It can also play videos formatted as WMV and display photos formatted as JPEG. You can convert audio files into MP3 using the Disney Mix Max software -- Mix It Plug-in. The plug-in works with Windows Media Player 10. This software CD came with the player and is not available online. To download music to the device, you can use Windows Media Player 10 or Windows.
Things You'll Need:
* USB cable
* Mix It Plug-In installation CD
Instructions
Convert Non-MP3 Files
Install Mix It Plug-In. Insert the Mix It Plug-in installation CD into the computer's optical drive. Click "Install Mix It Plug-In" when prompted. If no screen opens, double-click on the "My Computer" icon. Double-click on the installation CD icon. Then double-click on the setup or installation file; this file is often formatted as EXE. Select to have the program saved to your desktop. Then double-click on the desktop icon -- "disneymixitplugin" to open the setup wizard. Click "Next" in the setup screen. Follow any additional setup prompts.
Open Windows Media Player 10 and create a playlist. To create a playlist, click "Library" and select "Now Playing." Drag songs from your computer to the "Now Playlist List" pane. Click the "Now Playing List" title to open the menu and select "Save Playlist As." In the "Save As" dialog box, enter a name for the playlist and select "Save."
Open Mix It Plug-In. Select "Yes" when asked to save analysis information for your music files. The software will analyze each track's compatibility with the Disney Mix Max player.
Press "Go!" to start the conversion process. Once the process is complete, an inactive "Go!" will be displayed. All music that has been converted is still listed in your Windows Media Player 10 playlist. You are now ready to download music to the player using Windows Media Player.
Open Windows Media Player 10 on your computer.
Remove the USB jack cover located on the bottom of the Disney Mix Max. Insert the compatible end of the USB cable into the USB port on the Disney Mix Max. Insert the other end of the cable into the computer's USB port.
Click "Library" and click a playlist name. To create a playlist, click "Library" and select "Now Playing." Drag songs from your computer to the "Now Playlist List" pane. Click the "Now Playing List" title to open the menu and select "Save Playlist As." In the "Save As" dialog box, enter a name for the playlist and select "Save."
Select the "Sync List" tab and choose "Sync List" from the menu.
Verify the items to be synced to the Mix Max, or right-click on a song title and select "Delete" to remove it. Click "Start Sync" to download music to the Mix Max.
Windows
Insert the USB cable to the Disney Mix Max USB jack. Connect the player to the computer with the USB cable.
Click on the desktop "Start" menu and choose "My Computer."
Double-click on the "Removable Disk" that corresponds with your connected device.
Drag songs saved on your computer with your mouse into the Removable Disk folder.
Tips & Warnings
If you converted files using the Mix It Plug-In, you will need to use Windows Media Player 10 to sync them to the player.
4answers
Everio movie editing
First check sound settings on control panel, ensure volume is not at minimum and computer audio is not muted. Test playing a CD.
this is usually due to Media Player or whatever player you use on your pc, not having the right codecs to decompress sound from camera file.
Usually you sort it out upgrading media player, you can download update from links below.
  1. Windows Media Player 10
  2. Cumulative update for Windows Media Player 11 in Windows Vista
My sony mp3/4 player will not play videos
you have to sync those files with windows media converter then it will play them ive had success using arcsoft media converter 4 converting the file to wmv then using windows media player to sync that file to my sony mp3
2helpful
I have an emerson mp3 player and i don't know how to put media on it
find out what type of media you can play .if you can play wma then you just use your windows media player to sync to the device and then load your songs and video to the player using windows media player !! Then hit the sync button to load player!! If doesn't use wma then find out which type files it plays then find out which music service it syncs to!!swampratt200!!AAAEEE!!!
2answers
Syncing with Windows Media Player
Place the music files that you want to transfer into the My Music folder of your computer - Windows will re-read them, and then you can synchronize to your device. Also, make sure the hold/lock switch is not engaged on the mp3 player - it probably isn't, but just check.
-Tha Mp3 Doctor
2answers
HOW CAN I GET NEW MUSIC ON MY RCA M4002A MP3 PLAYER
Use Windows Media Player
The instructions in these pages, which are largely links, pertain to Windows Media Player 10 and 11 only.
Windows Media Player is made by Microsoft. The general help page for Windows Media Player is:
http://www.microsoft.com/windows/windowsmedia/default.mspx
Through this link, you can enter a variety of search terms that will help you find what you are looking for (exs.: “add files to my mp3 player”; “delete files from my mp3 player,” etc.)
Important Vocabulary:
The code word for “mp3 player” in Windows Media Player is “DEVICE” or “portable device”
The code word for adding files is “SYNC,” “syncing,” or “synchronizing”
The code word for copying files from CD is “RIP,” or “ripping”
The code word for files stored on both My Computer and my Mp3 player (when it is connected to the computer) is “LIBRARY”
To add files (SYNC) to your mp3 player using Windows Media Player 10:
http://www.microsoft.com/windowsxp/using/windowsmediaplayer/wmp10/harrison_wmp10.mspx
To add files (SYNC) to your mp3 player using Windows Media Player 11:
http://www.microsoft.com/windows/windowsmedia/player/faq/sync.mspx
To delete files from your mp3 player using Windows Media Player 10:
http://www.microsoft.com/windows/windowsmedia/knowledgecenter/mediaadvice/0085.mspx#EDF
To delete files from your mp3 player using Windows Media Player 11:
My Directions:
1. Connect your mp3 player to the computer
2. Open Windows Media Player
3. Click on the icon of your Mp3 player on the left-hand side of the Library
4. Click on the Songs, Tracks, or other Music Folder
5. Find a song or songs that you want to delete
6. Left-click the song once to highlight it
7. Press the “Delete” button on your computer’s keyboard
To copy (RIP) files from CD to Mp3 player using Windows Media Player 10:
http://www.microsoft.com/windowsxp/using/windowsmediaplayer/getstarted/ripcd.mspx
To copy (RIP) files from CD to Mp3 player using Windows Media Player 11:
http://www.microsoft.com/windows/windowsmedia/knowledgecenter/easystart/mp11guide.aspx#RippingCopySsongsfromCDstoYyourCcomputer
Cant upload onto facebook or play on windows media player slide show vidoeo made on Ulead MovieFactory for Toshiba
Greetings,
What video format did ya save the movie ?
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
1helpful
3answers
Synchronize
use windows media player. if you go to the top wher eit says now playing library rip burn and sync, choose sync then take songs from windows media player, limewire, or itunes and put them in windows media players then put them in the sync list and connect your mp3 then push start sync once you have all the music you want on the list. hope this helps you =)
5helpful
5answers
Audio out of sync
You may want to put the audio into the microphone-in of your laptop and make menu selections for audio via that line-in port when recording. I found as well that the audio sync was out of whack when trying to have it go with the video through the EasyCap..
Top Polaroid Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Bill Eager
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
