Question about Paradigm Monitor 70p Speaker
My paradigm 70Pa speaker took a lightnig hit and one has a blown woofer. can I gat parts? or find somewhere to get fixed?
Posted by gqsmith61 on
Anonymous
  • 405 Answers
I have a pair of Paradigm Monitor 3 V.2 High Def speakers for my front L&R home theater system. On speaker sounds very tinny with no bottom end. On inspection neither the main or tweeter loo
A few questions to help me help you: (1) Does the woofer cone move freely when you use your hands to move it (or do you feel friction)? (2) have you tried swapping the left speaker for the right to rule out the receiver as a cause?
How to Replace a paradigm monitor 9 v6 driver
Are you having trouble removing the driver? Just remove it and replace, keeping track of where the positive (red) terminal is and what cable is connected there. The part number should be printed on the back of the magnet.
1helpful
How to repair
Once you get the grill popped off, the screws are evident to remove for the woofer removal.
A stout putty knife keenly applied should get the grill off without damage.
Ps-1200-A sub woofer will not power up
Probably a blown fuse. If there's not one on the face of the amp, pull the amp and check for one next to the power cable.
How long should a powered sub woofer last? It's on 24/7, but is not abused with long, loud playing. Mostly regular TV.I have a Paradigm PS1000, about 10-12 years old.
There's no way of telling really! Even if something did go wrong there's no reason to say it couldn't be fixed very cheaply. It could last another 10 years or it could go wrong in the next few hours.
I will say one thing after 12 years of service and never off you certainly have had your monies worth!
Paradigm Monitor 9 v4 tweeter not working.
speaker is must likely blown. check to see if another tweeter works at that connection.
Woofer not working
hi..
sounds like the voice coil could be open or damaged. the woofer can be reconed. reconing replaces all the moving parts in the speaker frame returning to new condition in most cases.
thank u
rate me
Need to replace home theater subwoofer-Tivoli TDHT1 is the system
You please check the ohms with the woofer watts so that the same frequency of the woofer you can fix of different company, otherwise there will be damage of the circuit board so please use the appropriate frequency of woofer speakers.
Marantz sr6200 problem
I think it may be related to set up of crossover frequencies within 'menu'. There's a menu where speaker sizes are set, as far as I remember the lowest setting suggested crossower freq for sub somewhere at 80hz as default which may be too high of you have sub.
Top Paradigm Audio Players & Recorders Experts
Ekse
 Grubhead
Grubhead
Are you a Paradigm Audio Player and Recorder Expert? Answer questions, earn points and help others
