Question about Eclipse AVN5500 Car DVD Player
How do i set the clock on avn5500 - Eclipse AVN5500 Car DVD Player
Posted by guy_088 on
Anonymous
  • 86 Answers
Google eclipse user guide for avn 5500 the very top choice is what will hell you support for avn 5500 the user guide will take you directly to their site and find support tab. avn5500 is at the bottom of the page when you find it. good luck
Posted on Nov 05, 2009
Clock
heres the manual to download, there you can see how to set the clock
http://www.retrevo.com/support/Eclipse-AVN6600-Car-Videos-manual/id/552ag915/t/2/
2helpful
2answers
How do you start the clocks on this until?
From Eclipse tech support...
Basically, as they said: The clock is set by the GPS. The unit needs to be On.
[Quote]
AVN-5500 Setting Daylight Saving time: The clock is set by the GPS. The unit needs to be On. Push the [MENU]
button once, on the display touch the [SETUP] icon, then touch the [TIME ZONE] icon, and then select DAYLIGHT
SAVING On/Off. Push the [OK] icon to 2 times to exit. Tech Support[Quote]
So it does not appear that it can be performed manually.
I hope that helps
I need to know how to take apart an eclipse avn5500 and i needa schematic to that particular unit
try calling www.eclipse-web.com/us, i believe they started charging for this service manual. If im not mistaking, it is $15 + $8 shipping...
The same problem (eclipse AVN5500
what you are saying that dont make sense is your unit has a lock on it ? that the only way the radio will not work nav cd dont stop radio from working
Avn5500 says "disc check" when i try to play dvds
that is because they are burned DVD- try an original and it will work. Burned dvd's will heat up faster and cause the laser to read through the dvd,
2helpful
I need a dvd for an avn5500
Im just taking a guess, but i assume you are talking about a Navigation DVD disc. Does your deck say "Check Map Disc"? they are pretty expensive they range from $200-$400. depending on the version. i have a copy of the 2008 edtion nav disc ver. 2.2 for $75 you can contact me at [email protected]
Avn 5500 navigation
Hi,, just to be sure.. you have your map dvd in your radio while trying your gps right?
2helpful
I need a user manual for eclipse AVN5500
you can go to eclipse website and download it and print it
Avn5500
call 310 327 2151 ask for support...you are going to need original purchaser's name and maybe his mother,s maiden name..after that they'll walk you thru it...
Eclipse Avn5500
if you know your cousins name and where he got it you can call 800-233-2216 and unlock it by phone
Eclipse AVN5500 Car DVD Player Logo
Top Eclipse Car Audio & Video Experts
xxxxxx xxx
Steve Sweetleaf
Steve Sweetleaf
Are you an Eclipse Car Audio and Video Expert? Answer questions, earn points and help others
