Question about Cell Phones
When i insert sim there the lg ce0168 ask me for unlock code ?? please can anyone help me
Posted by Belulaj Dijar on
Anonymous
  • 129 Answers
If u have set a code on ur fone or on ur sim so use that code for it.other go to certified mobile repairer
Posted on Jan 07, 2010
Need to know if my phone call unlock it lg gplg441gb
How to Unlock LG (most models):
1. Insert not-allowed SIM card
2. Power on the handset- phone will display "phone restricted"
3. Select "Cancel" - phone will display "phone restriction code"
4. Enter the SIM unlock code
5. Select "OK" - the handset is now successfully unlocked
Unlock Instruction for LG TU720 (SHINE) and VU
1. Power ON your phone with not allowed sim card (one that didn't come with the phone)
2. Type *#865625#
3. the phone will ask you to input the unlock code twice, just input the unlock code
4. Device is now unlocked
How to Unlock LG KG800 or TG800 Chocolate:
1. With the phone in standby, enter 2945#*7101#. This will activate the extra menu.
2. Go to: Settings>Security>SimLock>Network
3. Select deactivate. Enter the unlock code
How to Unlock LG C2000:
1. Insert non-Cingular SIM card
2. Power on the handset - phone will display "phone restricted"
4. Enter the SIM Unlock code
How to Enter Unlock Codes on LG F2250:
1. With allowed sim card in the start menu type: 2945#*3311#.
2. Handset shows saved, then return to startup screen
3. Press Menu key, choose Settings > Security > Sim Lock> Network > Deactivate, handset will now show 'Enter NCK'
4. Enter your unlock code and OK.
How to Enter Unlock Codes on LG U8150:
1.
Switch ON your phone with a not allowed SIM card.
2.
Compose: 277634#*#.
3.
Go to menu "SIM Lock".
4.
How to Enter Unlock Codes on LG U8110:
1. With a not allowed sim card in your phone enter Pin code then validate, type: 277634#*#
2. Select 'Sim Unlock' menu #
3. Enter NCK code then validate
4. Your phone is now unlocked.
How to Enter Unlock Codes on LG U8210:
1. With a not allowed sim card enter Pin code then validate, type: 277634#*#
2. Shows test menu
3. Choose sim test menu and type: 2945#*#, choose Sim Unlock menu
4. Handset shows 'Enter NCK'
5. Enter code, then hit OK.
How to Enter Unlock Codes on LG U81xx:
1. To bring up the unlock menu on the phone with a SIM card, type 2945#*88110#
2. Enter the code
In case you need to reset the phone without a SIM card first, type 277634#*# or 47328545454#.
How to Enter Unlock Codes on Cingular AT&T LG CU500:
1.
Insert non-Cingular SIM card.
2.
Power on the handset. Phone will display "Invalid SmartChip"
3.
(IF THE PHONE DOES NOT DISPLAY INVALID SMARTCHIP, PLEASE POWER OFF AND ON AGAIN)
4.
In Idle screen, enter 159753#*#. Phone will display "Enter NCK, Remaining 5
5.
Enter the 8 digit SIM unlock code
6.
Select "OK". The handset is now successfully unlocked.
Unlock Instructions for LG KU990 (Viewty):
1. insert original sim card and turn phone on.
2. Press telephone icon at bottom of screen to bring up the phone keypad
3. Enter 2945#*990#
4. A menu will pop up, select sim unlock
5. Enter your unlock code and press ok
6. The phone will then reboot and the unlock is complete.
Unlock Instructions for LG KF600:
2. Enter 2945#*71001#
3. A menu will pop up to enter the sim unlock code
4. Enter your unlock code and press ok
5. The phone will then reboot and the unlock is complete.
Unlock Instructions for LG KF750 aka LG SECRET:
1. Insert original sim card and turn phone on.
2. Enter 2945#*750#
3. A menu will pop up, select sim unlock
Unlock Instructions for LG CU915:
1. Power ON your phone with an accepted SIM card.
2. Type *#865625#CODE
3. Press OK
How to Enter Unlock Codes on LG Incite CT810:
1.
Dial this into the LG Incite's phone menu
2.
2945#*810#
3. Press CALL.
4. It should you ask you for the code.
How to Enter Unlock Codes on LG Invision CB630:
1.
Insert an AT&T or Cingular SIM in the phone; it does not have to be an active SIM
2.
3.
*#865625#
4. Press CALL.
5. It should you ask you for the code.
How to Enter Unlock Codes on all other LG cell phones:
1.
Switch ON your phone with an allowed SIM card
2.
Then compose:
3.
2945#*5101# - (if you have a LG 510w)
4.
1945#*5101# - (if you have a LG 1200 & B1200)
5.
2945#*5221# - (if you have a LG 5200 & 52200)
6.
2945#*5301# - (if you have a LG 5300)
7.
2945#*5401# - (if you have a LG 5400)
8.
2945#*70001# - (if you have a LG 7020)
9.
2945#*7101# - (if you have a LG 7100)
10.
2945#*1201# or 2945#*70001# - (if you have a LG 1100)
11.
2945#*70001# - (if you have a LG7250T)
12.
2945#*2201# - (if you have a LG C2200)
13.
2945#*5301# - (if you have a LG T5100)
14.
2945#*3311# - (if you have a LG C3310)
15.
Go to "Menu" and then to "Settings"
16.
Then select "Security"
17.
To finish select "Network Provider" and select "Deactivate"
18.
19. If your cell phone is not listed, please follow instructions for LG C2000 above
How to Enter Unlock Codes on LG KE970 Shine:
1.
2.
Then compose: 2945#*9701#
3. Press CALL.
How to Enter Unlock Codes on CU575 / Trax and CU515
1. Put a non cingular sim in the phone ,phone says invalid smart chip
2. Now enter *#865625# then select option 1 and then again select 1 and enter your 16 digits code
Sep 29, 2016 | LG Cell Phones
Lg insert right sim
Your LG phone is restricted to some specific network. You must unlock it to make it work with any GSM SIM card. What is the exact model of your LG phone? "CE0168" is used in almost all mobile phones produced by Samsung,Lg and Motorola etc. It is written on the back label of a phone in bold letters so people often misunderstand it as a model number of that particular phone. Anyway, you can visit SuperUnlockCodes.com submit the required details and get the accurate unlock code for your LG phone at affordable cost with easy unlocking instructions.
Aug 05, 2014 | LG CE0168 Cellular Phone
My phone is lock , i use grameen but other sim not supporte and want code
HI DEARYOUR CELL IS LOCKEDTO UNLOCK YOUR YOU NEED UNLOCKING CODE HERE IS YOUR UNLOCKING CODE----80518751 INSERT OTHER SIM ,YOUR PHONE WILL ASK FOR THE CODE PLZ ENTER THE ABOVE CODEYOU CELL WILL BE UNLOCKEDNOTE:- IF PHONE DONT ASK FOR THE CODE JUST SEARCH WITH GOOGLE ON HOW TO ENTER THE CODE IN THE SAID MODEL MANNUALY
May 01, 2012 | LG CE0168 Cellular Phone
I need to unlock my lg ce0168
This is a 15 or 16 digit number that is normally found on the back of your phone, underneath where battery. If this code is provided then it does seem possible to be able to find the master code, which you can then type in and unlock your phone. How to enter LG CE0168 Unlock Code: 1- Power phone on with non-accepted SIM card 2- Dial 2945#*168# 3- Dial Unlock Code and Press the Dial button or OK 4- Phone should show, code accepted
Aug 01, 2011 | Cell Phones
I want to unlock my att lg c900 windows 7 phone i already got the code and the instructions but i insert the unaccepted sim card but it asks for the puk number i dial it in but it doesnt give me access to...
Are you sure you did correct instruction how to insert LG Quantum unlock code in your phone? As my knowledge when we do unlocking phone we insert the original sim card not the unaccepted sim card. Try doing that procedure again but this time use orignal sim card when you insert lg unlock code in your phone. Good luck!
Jun 16, 2011 | LG Quantum (16 GB) Smartphone
Id like to unlock my lgks360 for free but im finding it hard. could you give me a code to do this please?
Only trust best unlocking specialist for unlocking your mobile , it will be the best & safest way for unlocking . In order to unlock your Lg KS360 MOBILE make use of this site wickedunlock ,select the network you need , then get the unlock code here , using unlock code specified in it proceed unlocking your mobile & gain solution .
May 28, 2011 | LG Cell Phones
Security code for LG KP100 (t-mobiles)
i have a lg kp100, I already bought a code to unlock it, but i don't know how to insert it. the phone is locked to movistar(spain) and probably the sim has not a network anymore. I am in greece now so I tried with greek sim cards but still nothing.
when I put the spanish sim it shows me "error de tarjeta sim" wich means error with the sim card, but there is nowhere option to access to security mode to insert the unlock code.
if there is anyone who can help me please contact with me
[email protected]
Dec 10, 2009 | T-Mobile Sidekick ID Cellular Phone
UNLOCKING USIM
my LG CEO168/KC550 previously a contract phone with virgin i have put a pay as you go virgin sim in it but its telling me emergency calls only help
Jul 20, 2009 | LG CU500 Cellular Phone
Country code
Try unlock codes
Dec 31, 2008 | LG KU990 Viewty
Cell Phones Logo
140 people viewed this question
Top Cell Phones Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Cell Phone Expert? Answer questions, earn points and help others
