Question about Tablets & eReaders
RCA DTA800 TV Converter Box I need TV codes for the remote to work. The TVs are a GE, phillips magnabox
Posted by vanny74464 on
John Hall
    President:
  • 1,218 Answers
Good day,
I might be missing something, but you are describing a converter box that converts digital signals from an antenna to analog.
The converter box will be set to channel 3, and you should set your tv's to channel 3 as well.
Using the remotes that came with the tv's go into setup and if available as an option, you will find an option to select cable/antenna or automatic. Select automatic or antenna and save. If there is a selector switch on the back of the tv's, set to 3.
Connect antenna cable into input, and use supplied cable to connect from the output of the converter to your tv.
plug in power supply for converter box, tune tv to channel 3 then follow instructions to setup converter box including channel scan.
When done, the converter remote will control everything. However, the tv volume control will work even though the converter remote will have volume as well. The tv remote as well is needed to shut off or turn on tv. These functions can on most tv's be performed on the set as well.
No codes are required. The converter remote will work on any tv.
If you want to use both tv's then you will need a splitter on the output of the converter to send the signal to both tv's. Only one channel can be viewed at a time.
Viewing separate Chanel's requires a second converter box and a splitter connected to the antenna cable for viewing separate channels.
More options are possible, but I hope this helps you get started.
The converter box takes place of the tv's tuner and in essence disables it.
Posted on Nov 05, 2009
Poppy Chulo
  • 863 Answers
Here you go old chap:
http://www.thompsontv.com/rcarc.html
cheers
How to cancel and reset your email on kindle fire
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily....
http://electro-medical.blogspot.com/
Jan 07, 2017 | Tablets & eReaders
Is there a cable available to view on TV via RCA plugs?
I am not going to say no for sure but 90 percent sure there is not. The problem is you would have to scale the signal down to a composite signal. Now that can be done but at a pretty hefty cost and that is if the cable is available to come off of your tablet. From there it would have to go from 1080P to HD15. Then you would have to have a HD15 to composite scale converter. Then go to the tvs RCA input. The scale converter, the right one, is going to be about 200 bucks.
Mar 21, 2016 | Mach Speed Trio Stealth G2 Tablet -...
What cable do I need to hook up to TV to my RCA tablet
Depends on whether your tablet has USB to HDMI ability. You can also buy a converter however they require USB 3.0 and your tablet must have that capability.
Mar 20, 2016 | Samsung Tablets & eReaders
Whats the device code 8 letter code
RCAAV ' RCA Tablets - Audio - Video
https://rcaav.com/
Use it as a tablet or a conventional laptop, the Cambio is as dynamic as you are. ... Windows 10 gives you absolutely the best experience for doing what you do, with great ways to ... Our new Android 2-in-1s are your new go-to device. ... Thanks to RCA, cutting the cord and getting rid of your cable bill is a little less painful.Missing: letter
RCA Tablets ' Connect and Pair your RCA Pro 10 Edition ...
? 3:01
https://www.youtube.com/watch?v=sNELPDMQOOo
Apr 21, 2014 - Uploaded by RCA Tablets
RCA Tablets ' Connect and Pair your RCA Pro 10 Edition Tablet... 7:58. RCA Cambio 11.6 Inch Windows 10 Detachable Keyboard... 8:35. RCA Tablet Complete Disassembly - LCD/Glass/Power button fix ... Get embed code.
PAIRING YOUR MOBILE DEVICE TO YOUTUBE ON TV ...
? 4:05
https://www.youtube.com/watch?v=Tc5po_6MdD8
Nov 30, 2012 - Uploaded by Martin Charles Everington
Enter the pairing code shown on YouTube TV. .... le40C650 in the youtube application has no settings.. so i cant pair it... what else can i do?.
Jan 19, 2016 | RCA CA 7" Tablet with 4GB eory 28458515
How do I plug hdmi into tv?
Make sure that the TV is HDMI compatible first, if not then the only way would be to buy a converter cable. Older TVs won't be able to support HDMI, newer ones should have a port just like the one below:
Jan 11, 2016 | Amazon Kindle Fire HD 7in, 32GB
Rca 10" tablet need to connect to my phillips tv.Plug up nothing happens,Took a hdmi/rca cable from camera, hooked tablet to tv that made my tablets screen go black until unpluged from the tablet.
Screen going black usually means it is connected to another screen. Is there a setting on the tablet to enable output settings and a setting on the TV to enable input settings.
Jul 19, 2015 | Tablets & eReaders
Are rca tablets compatible with mhl cables
it is possible because RCA is selling mhl cables.
There is nothing definitive but worth a try. Mini HDMI Adapter HDMI Converter Cable
Apr 10, 2015 | Tablets & eReaders
I wANT TO CONNET MY LAPTOP TO MY CRT TV
What you need:
This is hard to define initially as there are so many ways to achieve this depending on what type of television you have and what video outputs your computer offers. You may also find that you only want to attach the stereo, and leave the TV disconnected, or vice versa.
.HDMI - High Definition Multimedia Interface: Ideally we will all have an HDMI connection on both our television and video card, but most likely don’t have it on either. Many new LCD screen and Plasma displays offer this mother of connections. They are also becoming a little more popular on Video cards. This will give you the highest quality signal. This format can also carry audio. This is very easy to connect from one device to another. It offers the same video quality as a DVI.
here are some tips that will help
Computer has HDMI and TV has HDMI – Use HDMI
Computer has DVI and TV has DVI – Use DVI
Computer has DVI and TV has VGA – Use VGA + Adaptor
Computer has VGA and TV has VGA – Use VGA
Computer has S-Video and TV has S-Video – Use S-Video
Computer has RCA and TV has RCA – Use RCA
Computer has S-Video and TV has RCA – Use RCA with adaptor
Computer has RCA and TV has S-Video – Use RCA with adaptor
Sep 10, 2009 | Gateway CX200S Tablet PC
Tablets & eReaders Logo
438 people viewed this question
Top Tablets & eReaders Experts
Marvin
Marvin
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
