Question about Brother MFC-7820N Printer
The toner life ended and then we got a refill. Earlier on refill, It was working fine, But this time it still says , TONER life end, replace toner. We tried loading 2 different refilled toners and cleaned the drum also . Still the problem persists.
Posted by sajid208 on
Roshan Rijal
    Sergeant:
  • 361 Answers
We can refil toner many times but we should reset cartage, while we refiling toner to open cartage we should sides white rings middle plastick flate white plate make adownof cartage it is first methode. when we put reffiling cartage put on printer and do on at that time we push cartage right side pointo re set. look on www.brother.com
Posted on Nov 05, 2009
I have Samsung ML-1666 Laser Printer. I am getting
I would not advise you to refill a toner cartridge becausethe toner powder is very fine and you do not want to breath in this tonerpowder.When the toner cartridge is exhausted or empty then theprinter will not be able to print further documents or the prints will be veryfaint.You may be able to print a few more pages by removing thetoner cartridge and shaking the toner cartridge in a horizontal position a fewtimes and then placing it back into the printer.This will give you an opportunity to print a few more pages and giveyou time to purchase a new toner cartridge for your printer. A cheaperalternative is to purchase a re-manufactured toner cartridge for your modelprinter.A re-manufactured printer cartridge also replaces worn partsas well as refilling with toner powder.
Jun 02, 2012 | Samsung Office Equipment & Supplies
Brother dcp 7055 printer toner ended error
i haver Brother Laserjet DCP 7055 printer. Once i refilled its toner but now on 2nd time i refilled it the printer is gives an "Toner Ended" error & replace the toner message.... Pls help meto solve it... Thanks lucky bareilly
Jan 10, 2012 | Office Equipment & Supplies
Pls tell me the life time of the developer powder and do I have to use only original toner
Hi, I have not come across any expiry date of toner/ developer and if it is stored properly in a cool dry place, away from sunlight an excessive heat, it works just fine. Re-filling the toner is always cheaper and costs around 1/4th of the new toner price. So, check for the price of new toner and compare. Genuine toner is always better in terms quality and yield. However, refill can work too.
I have refilled/ refurbished toners myself and had no issues. Properly re-filled/ refurbished cartridge would NOT cause any damage to the printer. So, you may get your toner refilled by some good professional and it would work fine. As for Panasonic Workio DP-4530 and similar copiers, the toner comes in a bottle (which is only a container filled with toner powder) and the toner powder is pulled by the toner supply unit of the copier. I am using HP 9065MFP and refilling caused no issues. I usually refill it after proper servicing and use best available powder and it works absolutely fine.
Hope it helps! Good Luck! Thanks for using Fixya! CreativeTECH
Sep 27, 2011 | Panasonic Workio DP-4530 Copier
I have a printer of Brother quality DCP7030..the toner life end appears on screen.but i have already refill the toner
Refilling printer toners/cartridges never show as full on the screens. Only if you buy a new toner, that will show a full cartridge.
Aug 26, 2011 | Computers & Internet
It tells me tone life end, I replaced drum unit and toner and it still says life end
try this. open the front cover, press the "options" button, then "start", then "1" then "0". once you see the message "close front cover", close it. if message comes back, you may have a faulty or "refilled" cartridge. if toner cart is not "reset" properly when refilled, you will get this message also.
good luck,
razors
Jan 14, 2011 | Brother MFC 7420 All-In-One Laser Printer
I replaced already new toner cartridge for my brother fax machine mfc-7220 but still the on screen message is appearing on the display "TONER LIFE END". Pls help me to solve this problem. Tnx and God bless...
I replaced already new toner cartridge for my brother fax machine mfc-2820 but still the on screen message is appearing on the display "TONER LIFE END".
Apr 12, 2010 | Panasonic KX-FL541 Plain Paper Laser Fax
MFC 9450 - CDN shows toner end of life message. The cartridges had been refilled from bottles. This was solved by resetting the flag gear so the printer thought it had a new cartridge. See this link. As...
You can reset the toner bias by opening the front cover of the printer so that you can see the toner cartridges and then press "clear/back".
This will access the toner reset menu and you can select which cartridge you are reseting.
Thanks,
Pat
Mar 25, 2010 | Brother MFC-8460N Laser Printer
Dcp 7020 and 7040 toner life end message premature, need override
When the Toner Life End LED flips on, requires you to replace the cartridge, even when there's still toner left in the cartridge. The machine detects end of life by shining a light through from one side to the other.
To circumvent the detection mechanism, remove the cartridge and put a piece of masking tape over or jam a little bit of paper into the clear opening/circle on the right side of the toner cartridge, and then pop the cartridge back in. Eventually, you'll start seeing streaks, and then you'll know that the cartridge is truly empty.
Jan 17, 2009 | Brother DCP-7020 All-In-One Laser Printer
MFC 8460N giving Toner Life End message
I just solved my own problem. Try it for yours. I had been using several compatible toners for the MFC-8460N with no problems until today, as I posted earlier. On a hunch, I went to the local office supply store and purchased one original Brothers TN550 toner and put it into the printer and closed the cover. Everything clicked. Toner End Life message gone. I then took that Brother toner out and put the compatible one back in and still everything was fine. Am keeping the original Brother toner as a "kickstarter" if it happens again.
Mar 10, 2008 | Brother MFC-8460N Laser Printer
Brother MFC-7820N Printer Logo
862 people viewed this question
Norman  J Weimar Jr
Norman J Weimar Jr
k24674
