i knew it was the switch, but all but one of the engineers, i have contacted says, that they dont touch goodmans tv`s, apart from one and he cannot get a hold of the part from anywhere, so im stuck with a tv that will not work.Cannot get in touch with goodmans, must be a swindle company.i knew it was the switch, but all but one of the engineers, i have contacted says, that they dont touch goodmans tv`s, apart from one and he cannot get a hold of the part from anywhere, so im stuck with a tv that will not work.Cannot get in touch with goodmans, must be a swindle company.
You can't post conmments that contain an email address.
The switch you could find from an electronic website, type it in on google or check on an auction site the switches are readily avalible and they havnt got to just be for the tv since alot of them are used in DVD players, cd players ect.The switch you could find from an electronic website, type it in on google or check on an auction site the switches are readily avalible and they havnt got to just be for the tv since alot of them are used in DVD players, cd players ect.
You need to set up the cable box remote for your TV , now you are just turning off the cable box. Some cable boxes have a switched plug on the back that will turn on and off with the box. If yours has the switched receptacle you can use that to turn the TV on and off by plugging your TV into the switched receptacle. Make sure the TV power is on, the receptacle will kill the power so the clock on the TV wont work. Otherwise you need to set the code for your TVs remote and use the system power button.
well first of all if anything happens when you push the button then the button works! I think you should leave this one to a professional technician. There is a circuit problem that will require advanced knowledge.
Try removing the batteries from the remote control, as a button may be stuck and is causing a repeated signal to be sent to the TV, possibly overriding any manual button actions.
Also unplug the TV for a few minutes and then plug it back in. You said that it wouldn't turn on when pressing the channel buttons on the TV, try the power button instead.
The problem of your TV is the power switch, and best solution for this is replacement with a good one. Warning: The next procedure must be done by an expert to avoid risk. 1.Open the the back cover of the TV and detached the board. 2.Try to see any broken solder or cut PCB lay-out on the board. 3.Get a continuity check to the switch.If the switch is defective replace it with a good one.
no reset button on the tv maybe the tv is shock when you switch on the tv cause sometimes lizard always stuck down the pcb...try check the horizontal output
Hiya this is how i got mine to work.Manually turn on the tv. Press and hold setup on your remote till the light comes on and stays on. Then press the tv button then release. The light will flash then continue to stay on. Now press and release the power button waiting 2 seconds before you press it again until your tv switches off.. you may have to press it for awhile. Once your tv cuts off press the mute button and now your remote is set for your tv.
