Sony BRAVIA KDL-32S2000 32 in. LCD HDTV Logo
Posted on Nov 05, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to change a sony bravia resolution from 480i to 1080i
Chi Chu
Level 3:
  • Sony Master 8,457 Answers
  • Posted on Nov 05, 2009
Chi Chu
Sony Master
Level 3:
Answers
8457
Questions
0
Helped
2820924
Points
26282
U can't not,only resolution can get,it the show u watching give u the resolutions.Want more HD 1080i must order a HD package from the cable,satalite or telicom companies.
I have a sony 3d tv model xbr-52hx909 how do you change the resolution from 1080i to 1080p
The resolution is controlled by the video sources, you do not adjust it at the TV, if you feed it with video sources that is 1080i it will display 1080i.
I hope that will explain how it works.
2helpful
How do I get my 52inch rca scenium to show 1080 using my ps3
Video Output Settings Adjust the system's video output settings. Select the best output settings for the TV in use.
1.
Check the resolution supported by your TV.
Resolution (video mode) varies depending on the TV type. For details, refer to the instructions supplied with the TV.
2.
Select in_setting.gif (Settings) > in_dispset.gif (Display Settings).
3.
Select [Video Output Settings].
4.
Select the connector type on your TV.
Resolution (video mode) varies depending on the type of connector used.
videooutput001.jpg Input connector on the TV Supported video modes (NTSC region) *1 Supported video modes (PAL region) *1 HDMI 1080p / 1080i / 720p / 480p 1080p / 1080i / 720p / 576p Component / D-Terminal *2 1080p / 1080i / 720p / 480p / 480i 1080p / 1080i / 720p / 576p / 576i Composite / S Video *3 480i 576i AV MULTI / SCART *4 480p / 480i 576p / 576i *1 The video mode options vary depending on the region where the PS3™ system was purchased. In North America, Asia and other NTSC regions, 480i video mode is displayed as [Standard (NTSC)]. In Europe and other PAL regions, 576i video mode is displayed as [Standard (PAL)]. For details, refer to the instructions supplied with the product.
*2 D-terminal is a connector type used mainly in Japan. The resolutions supported by D1-D5 are as follows:
D5: 1080p / 720p / 1080i / 480p / 480i
D4: 1080i / 720p / 480p / 480i
D3: 1080i / 480p / 480i
D2: 480p / 480i
D1: 480i
*3 Composite is the connector used to connect the AV cable that is supplied with the PS3™ system. S VIDEO is a format mainly used in Japan.
*4 AV MULTI is a format mainly used in Japan. SCART is a format mainly used in Europe. If [AV MULTI / SCART] is selected, the screen allowing you to select the type of output signal will be displayed.
5.
Change video output settings.
Change the resolution for the video output. Depending on the connector type selected in step 4, this screen may not be displayed.
videooutput003.jpg 6.
Set the resolution.
Select all resolutions supported by the TV in use. Video will automatically be output at the highest resolution possible for the content you are playing from among the selected resolutions.*
* The video resolution is selected in order of priority as follows: 1080p > 1080i > 720p > 480p/576p > Standard (NTSC:480i/PAL:576i).
If [Composite / S Video] is selected in step 4, the screen for selecting resolutions will not be displayed.
If [HDMI] is selected, you can also select to automatically adjust the resolution (the HDMI device must be turned on). In this case, the screen for selecting resolutions will not be displayed.
videooutput004.jpg 7.
Set the TV type.
Select the type of TV in use. Set when only SD resolution (NTSC:480p / 480i, PAL: 576p / 576i) is to be output such as when [Composite / S Video] or [AV MULTI / SCART] is selected in step 4.
videooutput005.jpg 8.
Check your settings.
Confirm that the image displayed is at the correct resolution for the TV. You can go back to a previous screen and revise the settings by pressing the in_left_key.gif button.
videooutput002.jpg 9.
Save your settings.
The video output settings are saved on the PS3™ system. You can continue on to set audio output settings. For details on audio output, see in_setting.gif (Settings) > in_soundset.gif (Sound Settings) > [Audio Output Settings] in this guide.
Source: http://manuals.playstation.net/document/en/ps3/current/settings/videooutput.html
I have a Sony Bravia kdl-32s2020 LCD with MPEG-2 DBV-T. Are there any possibility to upgrade them to DVB-C MPEG-4. This model is also HD-ready. Haw can convert them to FULL-HD (changing SD receiver with...
This tv have the capabillity for the Full HD max resolution 1080i or 1080p.The problems u have is not the tv capabilities.The tv incomming broadcasting signals are vary like DTV,SD,480i,720i low end HD.Max HD resolutions are 1080p or 1080i.
Need to change resolution to 720 on Vega 55 LCD. Hate 1080i
U can't change any air tv programs show on over the air resolution.Resolution are set by the tv stations set their programs by airing itself like 480i,720i and 1080i.U get what u get,the only thing is the tv programs air resolution air,the tv u got can get that resolution,that it.
Want to change my cable box from 1080i to 480i
U can't not change mode at will,the 480i or 1080i is determin by the show what mode is play on.1080i only in HD,more HD will need to order from ur cable,dish or telicom compannies.
2helpful
Even when I receive HDTV chanels, the display reflects only 480.
No adjustments can be made on the TV since the channels are being pick up with the resolution they are being broadcasted. Once the TV tunes to a digital channel(s), it will show the resolution to be either 480i, 720p or 1080i
2answers
I Have A Vizio 32LCD and my problem is i am trying to get the PS3 to play with the HDMI I have a HDMI cabel hooked up to the hdmi input on the back of the set and it is hooked up to to the HDMI input on...
1. Check the resolution supported by your TV.
2. Select (Display Settings) under (Settings) in the home menu.
3. Select [Video Output Settings].
4. Select the connector type on your TV.
D2: 480p / 480i
D1: 480i
5. Change video output settings.
6. Set the resolution.
7. Set the TV type.
8. Check your settings.
Confirm that the image displayed is at the correct resolution for the TV. You can go back to a previous screen and revise the settings by pressing the button.
9. Save your settings.
The video output settings are saved on the PS3™ system. You can continue on to set audio output settings. For details on audio output, see (Settings) > (Sound Settings) > [Audio Output Settings] in this guide.
Sony 2006 40s2010
It very much depends on:
the model of DVD player you have and whether it is a standard or blu-ray player
the settings on the player
the type of connection (component and HDMI will yield a better picture)
3answers
NO HIGH DEFINITION
  • HDTV capable: Yes (up to EDTV, 480p)
  • 0helpful
    Getting my Sony TV to operate in 1080i.
    Asumming you have set the Xbox at 1080i in the video settings and you have used all the four component lead ends, (apart from the yellow video end, as you won't need this) it should work.
    Top Sony Televison & Video Experts
    Grand Canyon Tech
    Grand Canyon Tech
    ZJ Limited
    ZJ Limited
    matt martin
    matt martin
    Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
