Lincoln Master
- Posted on Nov 05, 2009
Re: How do i replace left door mirior
Remove trim panel, remove mirror fasteners.
Glass, Outside Mirror—Town Car
Removal and Installation
Push upper edge of outside rear view mirror glass (17K707) into the outside rear view mirror to expose latch release.
Using a small flat-bladed screw driver or equivalent, move latch release to released position.
Remove outside rear view mirror glass mounting back and outside rear view mirror glass from outside rear view mirror.
Disconnect heater wire connectors and auto dimmer connector, if equipped.
To install reverse Removal procedure.
Mirror, Power—Outside Rear View
Town Car
Disconnect battery ground cable (14301). Refer to Section 14-01 .
Remove front door trim panel (23942). Refer to Section 01-05 .
Trim Panels, Door
Front—Town Car
Removal
Snap out two door pull strap retaining screw covers. Remove screws.
Remove three screws on front and rear side and center of front door trim panel (23942).
NOTE: The following procedure must be used during removal and installation of the door armrest and trim panel. Refer to the appropriate illustrations for component and vehicle model identification.
Using the Trim Pad Removing Tool from Rotunda Windshield and Moulding/Trim Removal Kit 107-R0401 or equivalent, pry the trim panel retaining clips from the door inner panel.
NOTE: Do not use front door trim panel to remove trim clips from door inner panel. Replace any bent, damaged or missing push pins.
Remove window regulator control switch housing from front door trim panel. Lift up housing in front and disconnect all connectors.
Disconnect wiring harness and heated seat switch electrical connectors if equipped.
Remove the door trim panel.
Disconnect two electrical connectors.
Remove nut from outside rear view mirror mounting base.
Swing outside rear view mirror (17682) toward driver door window glass to expose screw in mount base.
Remove screw from outside rear view mirror base.
Remove outside rear view mirror from front door (20124). Guide wiring and connectors through hole in front door.
To install, reverse Removal procedure. Tighten nuts to 8-10 Nm (71-88 lb-
