Vodavi Starplus SP-7314 Corded Phone Logo
Posted on Nov 05, 2009
Can't access Vodavi STS Starplus voicemail to program it
I just installed a used Vodavi STS Starplus system with voicemail card. When I try to dial into a voicemail group from a handset (dial 440), it just rings, but does not answer, so I can not program voicemail. And it does not respond to incoming calls. Any ideas?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 14, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1542
Points
THE VOICEMAIL OF OUR PHONE SYSTEM IS NOT WORKING RIGHT...
Have a vodavi sts and i keep losing dial tone. Have to call my phone provider to reset lines in order for dial tone to get restored
The sts system does not work very well with digital communications. But did you try powering down the system and then restarting it? On some of the cases I have worked on the seem to help.
Vodavi Starplus STS No Dial Tone, Plugged in to phone line
yes
These phones 3501-71 is that the model number ?
Are digital phones that you are plugging into an analogue phone line.
what you might need is a 3501-00 Vodavi/VerticalStarplus STSe Basic KSU
https://www.pcliquidations.com/p2820-vodavi-vertical-starplus-stse
or
http://www.americantelebrokers.com/vodavi-stse-3501-00-basic-key-service-unit-4x8x2-bksu-refurbished.html
these experts may be even able to advise if I am on the right solution .
look up on internet what a PABX is to get a deeper understanding .
On a Vodavi STS Starplus STS... Is there a way to lockout outside lines an a few stations but keep the intercom?
Sure. Restrictions are governed by the station Class of Service. COS6 is intercom only, or you can build tables and give a station some calling capabilities. There's also a traveling class of service and verified account codes to override your restrictions for users with a proper code.
COS descriptions are on pdf page 85 of the STSe manual http://www.wedophones.com/Manuals/Vodavi/Vodavi%20Starplus-STS/STARPLUS%20STSe%20Programming%20and%20Operations%20Manual.pdf
Carl
Hi. We need a wiring diagram for the Vodavi
http://www.wedophones.com/Manuals/Vodavi/Vodavi%20Starplus-STS/Starplus%20STS%
4helpful
Our church has a vodavi starplus sts phone system. one of the phones does not ring, can someone please tell us how to fix the problem.
You must go into CO line programming and put that station into the ring assignments for each outside line you want to ring at that station. It's Flash 40, page A, button 10.
11helpful
3answers
Cant figure out how to make it ring.
I am a Vodavi tech. Go to station 100 and with handset on hook dial **3226 and tell me what it does.
22helpful
6answers
Not able to access our main voicemail on Vodavi Starplus STS
To access the System Administrator Mailbox:
1. Dial into voice mail: From any phone on system dial 150
2. When the system answers, dial [*] + [#] followed by the System Administrator Mailbox number: (# 0 0 )
The system will announce: “Mailbox 15-00”, which is the System Administrator Mailbox number.
3. When requested, enter the System Administrator password. Default = [9]+[#]+[56].
How to program greetings
1. Access the System Administrator Mailbox as described above. The System Administrator Mailbox Menu plays.
2. Press [1] to access system greetings. The system will prompt you for the greeting number
3. Enter the desired greeting number.
For example:
1 = Default Day greeting
2 = Default Night greeting
3 = Default Temporary greeting
4. You will be prompted with the following three choices:
Press [1] to Review.
Press [2] to Record. You will be prompted to record the greeting
When you finish recording, press [#] to save the recording.
You can then
Press [*] + [*] + [*] to exit the system completely
Starplus STS answering in night mode during day
Phone system voicemail directory set to play night menu.
Top Vodavi Lands Phones Experts
vince
ADMIN Andrew
ADMIN Andrew
RAJA NADEEM AKHTER
RAJA NADEEM AKHTER
Are you a Vodavi Lands Phone Expert? Answer questions, earn points and help others
