Washing Machines Logo
Posted on Nov 05, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
LG wash machine # wm 2277 hb front loader display flashes LE wont
Wash machine Lg electronics model # wm 2277 hb front loader display flashes LE wont turn or spin
  • Anonymous Mar 20, 2014
    How do I get the LG Tromm model number WM 2277 HB started?
    How do I get the LG Tromm model number WM 2277 HB instructions to Start?
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Feb 21, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
839
Points
5
We had the OE message come up and did the above procedures...that didn't fix it. I removed the dual pump modules (they come off in one piece...one is the recirculating pump, the other is the drain pump). Turns out, the drain pump impeller design sucks. Even though it turned when I put power to the pump, that doesn't mean your pump isn't bad. Once it is under load pumping water, the impeller can slip where the pin connects to it from the motor. We replaced the motor for $60 and that fixed the problem. Our unit is at least three years old and we have a family of four, so it does get used quite often. Nobody told us about the filter at the bottom of the unit and I figure if we knew this ahead of time, we probably could have avoided the impeller issue...but it is still a sub-par designed motor/impeller. The new one I ordered looks like an updated design so I don't see this happening again. It is quite easy to remove and replace the pump, btw.
Anonymous
Level 3:
President:
  • Master 632 Answers
  • Posted on Nov 05, 2009
Anonymous
Master
Level 3:
President:
Answers
632
Questions
0
Helped
276390
Points
2196
It is a locked motor error. One of the following is causing the problem but you may need the help of a qualified appliance technician:
  1. The connector (3-pin, male, white) in the motor harness is not connected to the connector (3-pin, female, white) of the stator assembly. Connect them properly.
  2. The electrical contacts between the connectors (3-pin, male, white) in the motor harness and 4-pin, female, white connector in the main board assembly is bad or unstable. Clean the connectors and connect them properly.
  3. The motor harness between the stator assembly and main board assembly is cut or open. Reconnect or rewire.
  4. Motor winding is defective. Check the resistance between the terminals of the stator. Resistance should be between 5 to 10 ohms, else replace the stator with part number 1266809. Price ranges from $100 to $150.
  5. The hall sensor is out of order/defective. It is located at the stator assembly. If the hall sensor is out of order, it cannot detect magnetic field and the main board sees it as the rotor is locked then displaying the error code. Replace it if no evidence of defect is found above. Part number is 1268238 at about $25.
Le error sensor WM 2277 HS problem and solution please
Hello & Welcome to FixYa
LE error in your LG front load washer is displayed when either the motor is not working or the control board thinks that the motor is locked up. A Hall Effect sensor is used in these washers which monitors the speed and direction of the motor and then forwards this information to the control board. Hope you understand by now that this LE error is displayed when there is an issue with the motor or when the Hall Effect sensor sends wrong signal to the control. Conclusion is you'll have to check both motor and hall sensor and replace the part# that is bad, usually I have seen the sensor going bad. Please get back to me if you have any other questions.
Kevin
LE light flashes LG WM-2077HW Front Load Washer
most likely a defective motor hall sensor. 1st try unplugging power cord. it may reset.
2helpful
2answers
Le Error on front load machine
Hello,This a common problem for all front loaders. Your washer will not drain or work 'cause your outlet filter is clogged. Usually this small door is on the left side front below of your washer. Expect some water to come out when you open the door, etc. Clean out your filter and refit.....things should be fine.
Thanks
2helpful
2answers
LG WASHER
Unplug your machine for a few minutes or more and plug it back in. This will fix the LE error most of the time.
LG WM-2277 displays LE
I have exactly the same problem. The motor is covered by a 3 year warranty. You'll have to pay for labour. I will not buy any LG product in the future. Its junk.
Technician said the motor requires replacing. I believe its a computer module error. Some people were advised to unplug the machine for 2 hours and allow the computer to reboot! This does not sound like a mechanical issue. Whatever it is the machine is poorly developed and completely overpriced. Customer service is non-existent. Website is cumbersome and unhelpful. looks like a money grab to me by Lucky Goldstar (yes, LG is the new name for Goldstar, a low end appliance manufacturer of the past)
Disatisfied Customer (5 weeks out of warranty)
Richmond Hill
Ontario
LG washer
23d2381.jpg This info is right out of the LG Service Manual.. Hope this helps..
1helpful
2answers
LG Washer LE Error
Yes this is the same Hall sensor as in the WM 2277
You can Order them HERE and have them within a few days.
Easy fix
Top LG Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
