Question about Toshiba DKT-2020 Corded Phone
Change name display on Toshiba DKT2020-SD - Toshiba DKT-2020 Corded Phone
Posted by arichards151 on
Anonymous
    New Friend:
Press "intercom" button, then #621. Use * to move the cursor all the way to the left. Use the # sign to change from numbers to Alpha. For example: You want "N", but the "M" comes up. Press the "0" to toggle to additional letters on same number key. For a SPACE, use the number 1 and toggle to get a space.
Posted on Feb 01, 2010
J.R. Trowbridge
    New Friend:
  • 66 Answers
Dial Intercom (lower left button) dial #621, * moves cursor left # changes to Alpha and 0 toggles letter
Posted on Nov 24, 2009
5 Related Answers
Anonymous
SOURCE: Change name display on Toshiba DKT2020-SD
I am assuming you want to change the display to read another persons name, or blank. If that is correct:
Press a [DN](labeled intercom on my system) + #621.
That opens edit mode.
an example. My phone reads "MARK 29"
where Mark is the user, 29 the extension. John replaced
Mark, so target is "JOHN 29"
so intercom # 6 2 1 puts me in edit mode
# toggles between alpha/numeric
* moves the cursor, I repeat * until cursor is under M
Hit the 5 key, changes the M to J and moves cursor under the A.
Hit the 6 key, the A changes to M, and the cursor moves to under the R. I hit 0 which changes the M to N. I hit 0 again, the N changes to O.
Hit the 4 key, the R changes to G. Hit 0, G changes to H.
Hit the 6 key, K changes to M. Hit 0, that changes the K to M. Hit 0, M changes to N.
We are done, as the extension number stays the same. Hit spkr key to leave edit mode.
Hope that helps!
# toggles alpha/numeric
Posted on Dec 10, 2007
Anonymous
  • 106 Answers
SOURCE: Toshiba DKT2020-SD 20 Button Display Speaker Digital Telephone
To change the time, go to extension 10, while keeping the handset on hook, push intercom, then dial # 6 5 2, enter the new time ie. 102510 (hour, min, seconds), then push the redial key to save. That should do it. to set the day use the intercom # 653 code (1=Sun, 2=Mon, ect). To change the date use the intercom # 651 code (ie. 080510). If that does not do it, you may have a different model key service unit, and you will need to notate which system your using.
Posted on May 10, 2008
J.R. Trowbridge
  • 66 Answers
SOURCE: I am trying to change the name display on Toshiba
You are on a CTX system and are using the wrong code. On most CTX systems this must be done through the Admin software which is dealer propriety...good luck
J.R. Trowbridge
  • 66 Answers
SOURCE: NEED TO CHANGE TIME
On the main phone (ext 200 or 10) dial intercom #652 and enter HHMMSS then press redial. Your manuals and guides are here
http://guides.idacomusa.com/
Posted on Feb 11, 2010
consultel1
george peters
  • 860 Answers
SOURCE: DKT-2020 Corded Phone (dkt2020sd): How do you change the display time on the DKT2020-...
Depending on the type of system you have powering the 2020,this should take care of it.
Leave the handset on hook, press intercom # 6 5 2, then enter the time of a 24 hour clock, entering 2 digits for the hour, 2 digits for the minutes, and 2 digits for the seconds – enter a leading 0 for any single digit entered,
press Redial,
press Speaker.
This must be done at extension 200 – usually the receptionist phone.
For example, if the time is 2:15 P.M., press intercom # 6 5 2, 1 4 1 5 0 0, Redial Speaker
Posted on May 11, 2010
Sent to Extension on Display
Please send free brochure for model KX-TG 7874.
Jul 22, 2013 | Toshiba DKT-2020 Corded Phone
How do you change the display time on the DKT2020-SD?
Dear Friend, Hope this Video will help you OR
Click here and Read ...You will be Solved...
Thanks For Contacting FixYa...
May 13, 2010 | Toshiba DKT-2020 Corded Phone
press Redial,
press Speaker.
May 09, 2010 | Toshiba DKT-2020 Corded Phone
Trying to change the time on my Toshiba dkt2020-sd phone. I don't know how to do it.
FOR THE TOSHIBA DKT 2020-SD:
From main console phone (lowest extension number i.e. x100) pick up handset2_bing.gif and dial following codes:
For Time: Press "Intercom" and the numbers 652 enter the time in military format HHMMSS (HH=hours in 24hr clock, MM=minutes, SS=seconds) press "Redial".
Mar 15, 2010 | Toshiba DKT-2010 Corded Phone
I am trying to change the name display on Toshiba DKT2020-SD... I tryed using #612, or intercom #621 I have no DN button... I get DATA PROGRAMED...but cant seem to do anything from this screen. I know I am...
Nov 04, 2009 | Toshiba DKT-2020 Corded Phone
Toshiba DKT2020-SD phone how do i change the voicemail password
need to reset the voice message password from provider.
if from Toshiba kindls contact their service team
if from 3rd party voice message kindly contact the supplier
Feb 04, 2009 | Toshiba DKT-2010 Corded Phone
NEED TO CHANGE TIME
Jun 25, 2008 | Toshiba DKT2020SD Phone
May 09, 2008 | Lands Phones
Toshiba DKT-2020 Corded Phone Logo
1,698 people viewed this question
Top Toshiba Lands Phones Experts
Marvin
Marvin
Zaid Anarwala
Zaid Anarwala
Are you a Toshiba Lands Phone Expert? Answer questions, earn points and help others
