Question about Car Audio & Video
I have a JBL e8lf-18b849-ba amp from an old lincoln. I need to know how to hook up the wires and what the color codes on the factory harnesses mean. Any help/
Posted by tony24616 on
Anonymous
    Problem Solver:
  • 9 Answers
Usually the white stripes are positive. To be totally safe, what you may want to do is check to see if there is a wiring harness from a nearby car audio shop because that will SAFELY fix your problems. Another way to figure this our is to undo ALL of the speaker wires in the vehicle. Start out with 2 of the same colored wires(one solid and one striped) and connect them with their respective wires from which you disconnected them. Whichever speaker plays sound then that will be the speaker's wires that you are playing with.
Posted on Nov 05, 2009
I have a 2006 lincoln Navigator with the THX sound system. I need a colored wiring diagram so I can replace the head unit and hopefully retain the factory door speakers and amp. I already have my JL Audio...
You can buy an aftermarket radio harness adapter for your Navigator from ebay quite cheaply. I would not recommend butchering the factory wiring to install a replacement head unit. I found this one (will work as long as your Lincoln wasn't fitted with SATNAV) -
Lincoln Radio WIRE HARNESS INSTALL STEREO PLUG 2003 09 eBay
Sep 03, 2018 | Metra Car Audio & Video
88 vette aftermarket head unit stereo wireing diagram
Might be able to get an adaptor that plugs straight in painlessly.
Failing that it's the standard trace and identify method that eats time like crazy.
Apr 16, 2017 | Cars & Trucks
Wire a aftermarket stereo to 1997 Lincoln town car without using wiring harness
Why would you want to do that? Go to crutchfield.com and buy a harness for $25 With or without JBL Sysyem?
http://www.crutchfield.com/g_103000/Vehicle-specific-Wiring-Harnesses.html?tp=2977 Vehicle specific Wiring Harnesses
Jan 30, 2015 | 1997 Lincoln Town Car
What is the color code of a 1993 Lincoln Continental digital instrument cluster harness(wiring)?
I need wire color code for 1996 Lincoln town car
digital cluster ,please I need help wiring it up but can't find the color code
Oct 09, 2011 | 1993 Lincoln Continental
How to connect aftermarket radio into 2002 toyota camry JBL radio (the standart wiring doesn't work).Thanks
Your aftermarket radio should have color-coded wires which identifies power, ground, speakers, etc. most depaetment stores carry a radio harness adapter kit. This will connect to your radio's exact color coded wires, and will plug right in to your factory's wiring plug. And don't forget electrical tape.
Aug 28, 2011 | 2006 Toyota Camry
Jbl audio wiring diagram/schematics/color codes/ect.ect.ect.
http://documents.victorytechnologies.com//documents/product/2322.pdf
Mar 15, 2010 | JBL BP1200.1 Car Audio Amplifier
Need wiring color codes to install a new radio
the easiest way to install a new radio is to get the wiring harness adapter for your vehicle it runs about $25 and then you do not have to cut the factory harness. the wiring codes will come with the new harness and is just matching up there color code to the new stereos color code.
May 21, 2009 | 1994 Lincoln Town Car
Wiring color meaning
did you buy a factory radio connector to connect the old harness to the new radio wiring if not you can get one at wall mart for 20 dollars and it will be color coded
Mar 08, 2009 | Sony XPLOD CDX-GT200 CD Player
Car Audio & Video Logo
252 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
