If you have a DTP-16D phone, I believe that device was used primarily on the NEAX 2000 system by NEC. If that is true, you can try the default DND cancel code: #8 (*8 sets it). Unfortunately, the system codes CAN be changed by the installer, so it could be something else. Please let us know if that works. Thanks.
You need to enter the "Make Set Busy Deactivate Flexible Feature Code" - the "Flexible" part meaning the system administrator can change it, so you'll have to ask. The default appears to be #62.
I found that pressing Feature -> 99 -> Feature cleared it up. The Do Not Disturb option does not work either with what the owner's manual states, or the company's Website, to either activate it or deactivate.
Not sure how you set this feature but here is the solution:
To set DND you would have pressed your feature button, 60,and then feature button again (if you were forwarding to another extension you would have had to enter an extention after 60 and then the feature button. This sets your DND or call forward.
To eliminate press feature, 69 and then feature again this should cancel the call forawrd or do not disturb.
