This is a common problem. The water leaks from the large white rubber right angle hose that runs from the metal fill pan into the tank. It fills the top of the tank and then shorts across the heating element and trips the breaker. Because the tank is hot, it will evaporate pretty quickly and allow the breaker to be reset. But it will trip again the next time coffee is brewed. Either order a new hose and replace it, or caulk it with a high temperature food grade silicone.
Check the top of the tank something is leaking onto the electrical contacts.
