Hello what does f-51 mean on my maytag washer
Tabi, the Maytag folks state the F51 error code has to do with incorrect resistance reading from the motor. Without getting too technical, this can be caused by a number of problems. However, don't get discouraged yet.
A common problem with these washers is that it is relative easy for socks or other small articles of clothing to get ejected from the main tub and end up falling between the metal wash tub and the plastic tub that holds the water. Ultimately this prevents the wash tub from sitting centered and that can cause the F51 error.
Fortunately, this problem is easy to diagnose and fix. If you use a very stiff putty knife, you can release the spring clips that are about 6 inches in from each corner of the front of the machine. Once you have done that, you can raise the top of the machine. You can now use a flashlight and look down between the wash and outer tubs to see if anything is caught in there.
Please let me know if this helps or if you need more information.
