After loading softwear for either attachment if I then plug into usb port the pc reboots ! Unable to communicate with either device other usb devices working ok Any ideas ?
i,d suggest that the ports are incorrectly wired on the motherboard headers, Or possible Bent Pin on the USB shorting out, when device is connected. 5V+ and 5V- will cause the computer to Arc, and restart.
Unplug the pen (or any devices associated with it) from the computer.
1. Insert Disc and intstall the program.
2. When prompted, insert the device into the computer as instructed. Follow all instructions.
3. Once installed, remove disc, restart computer.
4. The computer will detect the device as the computer is loading. Wait for all "start up" programs to load, then select the program and it should open and operate.
If it is plugged into a USB Port, and is not being detected, try using another port. Do not plug such utilities into a Port Adapter, as it most likely will not be detected.
It must be plugged directly into a USB Port installed on the computer (or laptop).
Please let me know if you need further assistance.
I ended up solving this by briefly removing the memory card and the battery from the camera, then reinserting them. This seemed to re-set everything and it then all worked well!
Normal
0
Try disconnecting the Camera from the USB port and reinstall
the CD or Downloaded software program. When the program asks you
to connect the camera to the USB port, do so and it should work.
Hope this helps. Bud
digital camera + "dont have the orignal softwear that came with the camera." = another solution.
Try an USB memory card reader if you can't find replace software or CD's from the camera's maker.
