Question about Car Audio & Video
Whats color is the remote wire on the factory cd player on a 02 grand prix gt? (trying to install an amp)
Posted by kiwaniswilso on
Anonymous
    Problem Solver:
  • 9 Answers
It should probably be blue and if not it MAY be a wire that has the letters REM on it. If it doesn't then you will have to do process of elimination, Yellow, Red, Orange, and Black are NOT going to be it and the other wires will have a solid color on the wire coating and a solid with striped coated wire to go along with it(those will be speaker wires). The one that does not have a pair then there should be your answer.
Posted on Nov 05, 2009
I need a wiring harness diagram for 2006 Pontiac Grand Prix base model stereo system
http://www.modifiedlife.com/2006-pontiac-grand-prix-factory-stereo-install-diagram/
May 25, 2015 | 2006 Pontiac Grand Prix
Need wiring diagram for stereo on 2004 gt graned prix
There is no yellow on mine, I've been through numerous diagrams on here and they are all saying there is a yellow, Not to mention i have 3 green wires, 3 black wires. I can't figure out the wire colors on the Stereo!!!
Jun 16, 2012 | 2004 Pontiac Grand Prix
I need to kno what the colors for a 2003 Pontiac Grand Prix wire harness so i can hookup my new aftermarket cd player beacuse my old one was stolen and the wires were cut off and my factory harness was cut...
Try visiting the scosche or PAC websites to see if they have the vehicle side of the harness. I would recommend you install using the harness and a wiring harness. hope this helps.
Aug 22, 2011 | Car Audio & Video
CD stuck in Factory installed CD player
TRY REMOVING THE RADIO FUSE FOR 30 SECONDS THEN REINSTALL IT. THE CD PLAYER WILL SOMETIMES EJECT THE CD OR EVEN START WORKING PROPERLY AGAIN.
May 18, 2009 | 2006 Pontiac Grand Prix
1995 grand prix
do you have a test light?your speaker wires should be four sets of matching color,dark/light blue,dark/light green,dark/light purple and one other matching set of colors. then there should be one black wire which should be ground.with a test light you can find your power and accesory wires. your power wire will always have power with key on or off,the acc wire will only have power when key on. i hope this will help.
Aug 04, 2008 | 1995 Pontiac Grand Prix
Installing a new car radio
if you have a wiring harness al the wires are color coded to match the after market radios colors. the yellow constant wire goes to 12 volt or battery wire. the accessory wire would be the red wire that is the switched 12 volts. the remote is for the factory amp or an aftermarket amp which turns on and off it would be the blue with white wire.
May 28, 2008 | JVC KD-SX990 CD Player
Wiring harness problem
Try either crutchfield or modifiedlife.com
Apr 29, 2008 | Pioneer DEH-P3100 CD Player
Jensen head unit VM9311TS no sound from CD
Should wire HU's Power Const to Amp's Remote On. Instead you wired HU's Power Antenna to Amp's Remote On. So the stock amp got triggered only in radio mode.
Jan 24, 2008 | Jensen VM9020TS Car DVD Player
Car Audio & Video Logo
79 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
